GFCI Hisses. - Electrical - DIY Chatroom Home Improvement Forum
Old 04-10-2010, 05:12 PM   #1
GFCI Hisses.
Hello everyone,I hope your day is going well and as planed.
I have a question about a GFCI.
It seems to be working fine,it resets just fine.Its been outside for a year and now after the winter rains(I had the breaker off over the winter) it hisses off and on,Iam not sure if its bad though.
Any ideas?
Thank you,this seems like a wonderful forum.Iam sure Ill be on often.
God bless.
Apostle is offline   Reply With Quote
Old 04-10-2010, 05:46 PM   #2
Contaminated and semi-conductive water is boiling inside it from current flow, not from heat? If so, it should stop hissing after a short while.
The Following User Says Thank You to Yoyizit For This Useful Post:
Apostle (04-10-2010)
Old 04-10-2010, 05:56 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 478
Turn the breaker back off, pull the receptacle and replace it!
Hissing means arcing, means fire could be waiting to happen!
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
Old 04-10-2010, 06:00 PM   #4
Thank you both!
Ill replace it.It does hiss pretty loud at times.
Blessings.
Old 04-10-2010, 06:04 PM   #5
joed's Avatar
Rewards Points: 12,872
Bugs? Power off, pull and inspect it.
Old 04-10-2010, 06:13 PM   #6
That did happen to the last one,it was full of Fire Ants and the GFCI fried.
But this one looks Ok.
Old 04-11-2010, 03:13 PM   #7
With nothing plugged into it, you could measure the current draw into the "line" terminals.
It should only take a few dozen mA of AC to power the electronics and the LED, if it has one. Arcing and water boiling should take substantially more current and arcing should make noise in a nearby AM radio.
Apostle (04-11-2010)
Old 04-11-2010, 08:34 PM   #8
Thumbs up
One possible cause (for the hissing and destruction of the GFCI receptacle) could be momentary loss of the Neutral or a power surge! In any case, it should be replaced!
spark plug is offline   Reply With Quote
The Following User Says Thank You to spark plug For This Useful Post:
Freezer tripping GFCI davidclements Appliances 58 07-03-2015 05:46 AM
GFCI Stumper ksqrdks Electrical 2 04-03-2010 06:24 AM
Gfci Circuit howard.wheaton Electrical 10 01-29-2009 05:14 PM
GFCI Question Mdbuilder Electrical 6 06-19-2008 03:15 PM
GFCI questions 5circles Electrical 4 11-05-2007 08:24 PM
