GFCI And Grounds For Bathroom Wall Sconces? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-02-2012, 06:06 PM   #1
Rewards Points: 83
GFCI and grounds for bathroom wall sconces?
Howdy all,
I've made it into the bathroom today in my receptacle-rewiring project.
There are two wall sconces above the vanity that pull power from the bathroom-receptacle circuit. When I put everything back together, should I wire the sconces in on the "load" side of the GFCI?
These sconces have metal bodies, are mounted on metal boxes with metal screws and metal plates. When they go back together, the grounds in the 12-2 will actually be connected. But, there is no ground wire into the fixtures themselves - what do I do, or do I need to do anything?
Thanks again for everyone's help. Ya'll are making this go much more easily than it could have!
Jim
simanco is offline   Reply With Quote
Old 07-02-2012, 06:28 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 252
Doesn't matter if it is on the load side or line side.
I prefer to keep lights off the load side, unless the manufacturer requires them.
The Following 2 Users Say Thank You to jbfan For This Useful Post:
andrew79 (07-02-2012), plummen (07-04-2012)
Old 07-04-2012, 09:37 AM   #3
Cruising into the sunset
JulieMor's Avatar
Rewards Points: 518
Check your local codes. Around here, it's required to protect everything in the bathroom with a GFCI.
JulieMor is offline   Reply With Quote
Old 07-04-2012, 10:17 AM   #4
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
State amendment or some yahoos opinion?
Old 07-04-2012, 11:35 AM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I knew the Chicago area was screwed up with their conduit requirements, but I hadn't heard of the bathroom needing GFI protection.
Old 07-04-2012, 11:55 AM   #6
jbfan's Avatar
Rewards Points: 252
That is just strange!
Old 07-04-2012, 11:57 AM   #7
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
I normally run bathroom lighting on a seperate 15a circuit ,bathroom plugs on their own 20a gfi protected circuit
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
GFCI grounding; and inside double gang box? Wildswalle Electrical 5 05-29-2011 02:25 PM
Switched GFCI CrazyRay Electrical 9 03-21-2010 06:46 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 08:52 PM
gfci in main feeding sub panel problem scott2332 Electrical 12 02-26-2009 12:17 AM
Hot Tub GFCI Grounding Question kearnak1420 Electrical 3 04-30-2008 06:48 PM
