GFCI and grounded conductors
You need four wires (not counting grounding conductor) from the J box through the pipe to the outside.
1. (Unprotected) neutral (grounded conductor)
2. Raw hot going out
3. GFCI Protected unswitched hot coming back
4. GFCI protected switched hot from switch loop
You need four wires from the J box over to the indoor switch/receptacle.
5. Unprotected neutral directly from J-box
6. Raw hot for receptacle only, from J-box
7. GFCI protected unswitched hot for switch only, from the outside via J-box
8. (GFCI protected) switched hot back to the outside via J-box
You really don't want the inside receptacle to be protected by an outdoor GFCI. If the GFCI tripped, you would have to go outside to reset it. If you insist you can do it this way:
Five wires from the J box through the pipe to the outside.
9. GFCI protected neutral coming back for switch loop
And three wires from the J box over to the indoor switch/receptacle.
5a. GFCI protected neutral from outside via J-box
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
