GFCI Ground Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 10-24-2012, 08:30 PM   #1
GFCI ground wire
I am connecting a regular plug to a GFCI plug. Once the regular plug is connected to the GFCI plug I want to run two GFCI plugs in series. First: Can one connect a regular plug to a GFCI with no problems? Second: After connecting the first GFCI plug I want to run a wire off the bottom of the first GFCI plug to the second creating a series of two GFCI plugs. The white and black wires are easy. Two additional screws at the bottom. My problem is the ground wire. How does the ground wire from GFCI plug one connect to GFCI plug two? I would like to thank those who help in advance. Dennis.
MARKEN is offline   Reply With Quote
Old 10-24-2012, 10:07 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 144
You do not need to run a second gfci from the first if you use the load side.
The grounds need to be pigtailed and only one wire under the screw.
jbfan is online now   Reply With Quote
Old 10-25-2012, 07:44 AM   #3
Rewards Points: 1,418
All the ground wires entering the box are connected together. Use a short length (pigtal) of green or bare to reach the ground screw on the receptacle if the receptacle did not come with a green wire to connect up to the other ground wires.
For extending GFCI protection to additional plain receptacles, be sure that the neutrals of these (load side) continuing cables are connected together but as a separate bundle from the (line side) neutral(s) of the power feed for the GFCI and any continuing cables not receiving GFCI protection here.
Old 10-25-2012, 01:42 PM   #4
AllenJ & jbfan thanks for the help. I now have power in the greenhouse and feel comfortable my wife will not get shocked. That my friends would bring much pain. Not for her, ME!!! Thanks again. Dennis
2 Similar GFCI, but one tests open ground crescere Electrical 40 08-28-2012 10:19 PM
gfci boman47k Electrical 4 03-10-2012 07:18 AM
Replacing outlet - no ground wire clydesdale Electrical 17 12-18-2011 03:29 AM
GFCI feeing subpanel question scott2332 Electrical 45 02-28-2009 04:15 PM
Ground rod or not? brotherman Electrical 30 07-15-2008 05:58 PM
