GFCI In Garage? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-27-2008, 10:24 PM   #1
DIY Expert in Training!
GFCI in garage?
I am about to overhaul my attached garage. I plan on installing 4 20amp outlets. Do all need to be GFCI or just the first in the line?
gone_fishing is offline   Reply With Quote
Old 12-27-2008, 10:36 PM   #2
Electrician
Depends on how they are wired.
chris75 is offline   Reply With Quote
Old 12-27-2008, 10:56 PM   #3
Rewards Points: 1,418
Each garage receptacle needs GFCI protection. This can usually be accomplished with one GFCI unit per circuit located either at your panel as a breaker or at the first outlet box as a GFCI receptacle unit.
When a 120/240 volt circuit (with one neutral) is run to the garage, usually the easiest way or providing GFCI protection is to use a double wide GFCI breaker in your panel.
Old 12-27-2008, 11:19 PM   #4
Allan, so I can run a new 20amp circuit and make the first outlet a GFCI and the rest regular 20amp outlets?
Old 12-27-2008, 11:27 PM   #5
Rewards Points: 506
Send a message via AIM to theatretch85
Yes. Just make sure to daisy chain the outlets and wire the additional outlets from the LOAD terminals on the GFCI.
theatretch85 is offline   Reply With Quote
Old 12-28-2008, 01:00 PM   #6
Rewards Points: 35
There should be instructions in the GFCI box. All the ones I've bought have a little sheet with diagrams explaining how to connect them as standalone or chained.
BataviaJim is offline   Reply With Quote
Old 12-28-2008, 01:06 PM   #7
Registered User
Termite's Avatar
GFCI breakers in the panel are a huge inconvenience unless the panel is conveniently located in the garage. Only one GFCI receptacle is needed per circuit, as the downstream receptacles can be wired off the GFCI's load terminals.
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
Garage Door Install marly General DIY Discussions 2 11-17-2008 03:51 PM
Garage GFCI on Subpanel sweaty Electrical 2 09-20-2008 01:29 PM
GFCI in detached garage question WShawn Electrical 2 08-02-2008 04:27 PM
GFCI Question Mdbuilder Electrical 6 06-19-2008 04:15 PM
