Gfci Feed For A 3-speed Fan Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 06-08-2011, 09:21 PM   #1
Post
gfci feed for a 3-speed fan switch
how can i trouble shoot this problem: when fan switch is turned on, it trips the gfci and won't reset?
woodpix is offline   Reply With Quote
Old 06-08-2011, 10:18 PM   #2
do you mean a gfci outlet>>
is the neutral from the fan connected separate from the ground wire and connected to the gfci on load side??you have a leakage from the hot to the ground somehow
also the gfci may be faulty
RDS1958 is offline   Reply With Quote
Light switch installation problems pc_clone Electrical 8 11-30-2009 09:25 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
GFCI & Single Pole Switch combo II Weeks Electrical 12 04-10-2009 05:57 PM
Replacing outlet to new GFCI - Wall switch Protonix Electrical 13 04-09-2009 08:36 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
