GFCI Failure - Electrical - DIY Chatroom Home Improvement Forum
Old 12-11-2008, 07:19 PM   #1
Rewards Points: 820
GFCI failure
Hi;
Does a GFCI receptacle interrupt both hot and neutral when it trips, or just the hot?
I have one where I did some work, and now there is no neutral.
I suspect the receptacle, because the silver (neutral) screw fell out while I was working on it, and when I screwed it back in, the whole thing seemed a bit questionable. I wanted to replace it, but I didn't have another one.
I want to get one of a better quality. Can someone tell me what brand I should look for?
Edit: I just did some testing on another GFCI receptacle and found that it does cut both hot and neutral when it trips. I guess that's standard, since it would work if the device is reverse wired.
So, I am sure that I have a bad GFCI.
Ultrarunner2017 is offline   Reply With Quote
Old 12-11-2008, 08:05 PM   #2
dSilanskas's Avatar
Go to the electrical store and get a P&S GFCI
dSilanskas is offline   Reply With Quote
Old 12-11-2008, 08:31 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
I like Cooper devices. Any name brand is fine, I just don't care for Leviton.
Old 12-11-2008, 08:50 PM   #4
Originally Posted by KE2KB View Post
Hi;
I think it has to interrupt both because it only knows there is a current difference, not which conductor has the deficit.
There's probably a UL spec on this aspect of its design.
Old 12-11-2008, 08:59 PM   #5
Rewards Points: 1,418
I would not consider a device poor quality just because the terminal wiggles; it might have a wire connection inside as opposed to a metal strip connection.
I would not conside a device poor quality just because the screw came all the way out, although if the screw is loose and apt to strip its threads then we have a problem.
A reminder, additional loads may be connected to the load side neutral of a GFCI unless the matching hot conductor is connected to the load side hot terminal of that GFCI. Vice versa too.
Old 12-11-2008, 09:03 PM   #6
Rewards Points: 820
Yea, Leviton makes some real junk. They probably have a commercial or industrial line too, but I've not seen it at HD.
I'll look for one of the brands you guys mentioned (besides Leviton)
Old 12-11-2008, 09:04 PM   #7
Rewards Points: 820
There is nothing connected to the load terminals of the GFCI.
This one doesn't really fit into the box. It seems to be bottoming out on a wire nut or maybe an internal connector.
The whole thing is a nightmare, but I don't have time or $$ to rewire it right now.
Old 12-11-2008, 09:05 PM   #8
Rewards Points: 820
Agreed.
Freezer tripping GFCI davidclements Appliances 58 07-03-2015 06:46 AM
new gfci on new circuit pops rtoni Electrical 39 11-15-2008 11:18 AM
GFCI Question Mdbuilder Electrical 6 06-19-2008 04:15 PM
GFCI questions 5circles Electrical 4 11-05-2007 09:24 PM
