GFCI To Existing Lighting Or Switch - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-16-2013, 06:01 PM   #16
Much clearer, thank you. It really does help to write correctly.
Now, please answer the other questions. Does your wiring have a ground, or is it a two-wire system only?
Also, what is the purpose of controlling the outlet using the motion sensor?
Pros or others: is the bath recep allowed to be controlled by the motion switch?
RoyalAcresRod is offline   Reply With Quote
Old 09-16-2013, 06:07 PM   #17
its a two wire system
the motion switch has a red(load) black(hot) green(ground) I attached the green ground to the handy box
I wired both red wire (load)
I wired both black wire (hot)
Now I like to add a GFCI to the switch
bravo659 is offline   Reply With Quote
Old 09-18-2013, 09:42 AM   #18
Bravo
Sorry for delay in getting back tp you. As Jim suggested, you probably do not have a neutral wire in your switch box.
What you probably have is a switch loop: a hot wire coming in to the switch, a switch to control the circuit, and the other wire goes to the light. You cannot wire an outlet from the switch.
As was suggested, to meet code you need to have a new circuit from your fuse or breaker box run to a GFCI receptacle.
Someone please advise: Would it be against code to wire a new outlet off the existing bath light?
It's sounds like he has a two-wire ungrounded system. I understand a GFCI outlet with the "No Ground" sticker would have to be used, but can it be added to his existing lighting circuit, and does the amperage if circuit matter?
The Following User Says Thank You to RoyalAcresRod For This Useful Post:
bravo659 (11-03-2013)
Old 11-03-2013, 05:24 PM   #19
No one replied. I will be taking the power from the light to the gfci.
I will post images to show if its done correctly. Thanks.
Installing Switch and Tamper Resistant GFCI Outlet jasonbran16 Electrical 4 09-09-2013 12:31 AM
3-Way Switch Confusion / Convert to GFCI natedro Electrical 7 07-28-2012 06:07 PM
Powering a new single pole switch off of an existing three way switch set? jamesm067 Electrical 3 01-17-2012 08:36 AM
Existing switch, replace with combo switch/outlet shujinko Electrical 4 04-30-2011 06:19 PM
recessed lighting wiring to 3way switch DIY4EVER Electrical 1 07-12-2007 02:35 PM
