GFCI To Existing Lighting Or Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 09-15-2013, 08:41 AM   #1
Smile
GFCI to existing lighting or switch
Hi, in the bathroom my switch is a motion switch which I installed.
Works great.
However now I need to install a GFCI.
When installing the motion switch I have two wires, one is red serve as neutral and black serve as hot currently a 15a.
I made a green neutral attached to the box.
I want to install a gfci to the motion switch if possible. I was told I cannot but can do it by running a pigtail from the light having constant power.
All assistance and feedback are welcome.
Thanks to all.
Bravo659
bravo659 is offline   Reply With Quote
Old 09-15-2013, 09:46 AM   #2
Rewards Points: 14,312
Why? Around here only the outlets need to be GFI.
Old 09-15-2013, 10:29 AM   #3
I would encourage you to pick up a basic wiring book. Neutrals must be white. Grounds are green. You say you hooked up a green "neutral" to the box. Do you mean ground?
What is the purpose of having the outlet controlled by a motion detector? Is there no outlet currently installed?
RoyalAcresRod is offline   Reply With Quote
Old 09-15-2013, 10:30 AM   #4
Civil Engineer
Rewards Points: 4,944
Your post was a bit confusing. Are you trying to install a GFCI protected outlet off a light switch? Or are you trying to add GFCI protection to the light?
Daniel Holzman is online now   Reply With Quote
Old 09-15-2013, 11:31 AM   #5
when you buy that basic wiring book buy a tester also
Old 09-15-2013, 08:33 PM   #6
Rewards Points: 150
Hopefully you didn't do a bootleg ground. Very dangerous
romex1220 is offline   Reply With Quote
Old 09-16-2013, 04:34 PM   #7
Smile
I am trying to add the gfci to the switch.
If I cant do it from the switch can I do it from the light?
Here is what I currently have.
switch Red and Black.
I have a tester turned off the buss fuse the round type
checked the black wire still had current/power
checked the red wire no current/power
there is no green wire for ground
the new switch I added already had the green ground, red wire (load) and black wire (hot)
Now I like to add the GFCI to either the light or the switch.
Old 09-16-2013, 04:35 PM   #8
I attached the green ground to the box.
Old 09-16-2013, 04:36 PM   #9
the power source from the switch is constant
Old 09-16-2013, 04:37 PM   #10
I need an outlet instead of a regular outlet its a gfci outlet which is what I am trying to install in the bathroom
lol
Old 09-16-2013, 04:40 PM   #11
You said, "have a tester turned off the buss fuse the round type."
That sentence makes no sense. Please rewrite using punctuation.
Does your house wiring have a ground, or is it only a two-wire system.
Old 09-16-2013, 04:53 PM   #12
ok here we go
I already have a tester.
I turned off the power to the bathroom by disconnecting the screw in type fuse.
I checked the wire black for hot
checked the red wire no power
Hope this is clear
Old 09-16-2013, 04:58 PM   #13
Licensed electrician
Rewards Points: 1,882
It does not sound like you have a neutral in the box. You will need to find another source of power. To be code compliant the receptacle would need a 20 amp circuit dedicated to the bathroom as you are installing new wiring.
Old 09-16-2013, 04:58 PM   #14
I thought it to be interchangeable I guess is not.
Sorry for the confusion.
neutrals are usually the white wire and hot the black wire
but in my case its the red wire as neutral and the black wire hot but no ground exist. Meaning the green ground wire or bare copper wire.
Old 09-16-2013, 04:59 PM   #15
Hi Jim this mean that the red wire is a secondary hot wire?
Installing Switch and Tamper Resistant GFCI Outlet jasonbran16 Electrical 4 09-08-2013 11:31 PM
3-Way Switch Confusion / Convert to GFCI natedro Electrical 7 07-28-2012 05:07 PM
Powering a new single pole switch off of an existing three way switch set? jamesm067 Electrical 3 01-17-2012 07:36 AM
Existing switch, replace with combo switch/outlet shujinko Electrical 4 04-30-2011 05:19 PM
recessed lighting wiring to 3way switch DIY4EVER Electrical 1 07-12-2007 01:35 PM
