Gfci In Detached Garage For Shop Tools - Electrical - DIY Chatroom Home Improvement Forum
Old 12-27-2011, 09:59 PM   #1
Rewards Points: 152
gfci in detached garage for shop tools
NEC 210-8(A)2 & 5 All 125-volt, single-phase, 15-, and 20- ampere recepticles installed in locations specified in (1) through (8) shall have ground fault circuit interrupter protection for personnel.
Does the above NEC requirement allow me to forgo installing 240 volt gfci breakers for my table saw (20 amp), dust collector (30amp), and planer (20amp) in my detached garage building/shop?
All the readily accesible 120v plugs I planned for GFCI's as required. I wasn't for the 240v stuff.
n175h is offline   Reply With Quote
Old 12-27-2011, 10:02 PM   #2
Licensed electrician
Rewards Points: 1,034
As you posted only the 120 volt requires the GFI protection. The 240 volt circuits do not require it.
plummen (12-28-2011)
Old 12-27-2011, 10:03 PM   #3
jproffer's Avatar
Rewards Points: 702
I'd say it does.
EDIT: LOL, I'm too slow.
jproffer is offline   Reply With Quote
Old 12-27-2011, 11:01 PM   #4
Rewards Points: 152
Thanks for the replies.
I kind of found the answer from Mike Holt's youtube forums while you guys were posting. The only place it came up as a requirement was in boat dock lifts. It is required there, and it seems on 240 volt hot tub pumps.
Thanks for the help.
Happy New Year
Old 12-27-2011, 11:12 PM   #5
Rewards Points: 6,652
Happy New Year
What, you mean the NEC has not been telling everything for as long as it has been out.
Old 12-28-2011, 12:45 PM   #6
Rewards Points: 58
Happy New Year
GFCI protection is required in many more places than the two you mention. I bet you have several more instances in your house.
Old 12-28-2011, 05:57 PM   #7
Rewards Points: 152
It's only for the detached shed and the 3 tools mentions above, nothing done in the house in this project.
MWBC to detached Garage Lacklustre Electrical 1 11-16-2011 05:44 PM
Moving electric service entrance to detached garage WillK Electrical 7 10-05-2011 11:13 PM
subpanel in detached garage in NJ help Tedean Electrical 2 03-13-2011 11:46 PM
Painting Detached Garage Exterior bsmith95610 Painting 3 02-15-2011 07:52 PM
wiring 100A to detached garage snowman Electrical 4 11-28-2009 05:53 PM
