GFCI As Culprit? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-31-2013, 12:14 PM   #1
Rewards Points: 323
GFCI as culprit?
I'm not really a do-it-myselfer, but I like to have a basic understanding before I hire, because some tradesmen add things without my knowledge and without explaining it -- like I was getting ready to plug in my AC when I noticed an outlet that had a little light in it with the barely visible words "test" and "reset." So I pushed the buttons, and the circuit (the other outlets on that wall) went dead.
I went outside to the box. Please see the picture where it shows the two switches for the AC on the left. One is up and one is down. Did the GFCI cause one switch to pop up? In the normal position, are they both supposed to be switched in the same direction (like the other switches next to the AC switches).
Which of the AC switches is on? The one on the left says "on" but is that the one that is off? If that's the one that's off, should I flip it up? Thank you.
DIherself is offline   Reply With Quote
Old 07-31-2013, 01:15 PM   #2
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Did you "reset" the GFCI?
sublime2 is offline   Reply With Quote
The Following User Says Thank You to sublime2 For This Useful Post:
DIherself (08-02-2013)
Old 07-31-2013, 01:31 PM   #3
Rewards Points: 323
I pushed the reset button, and that's when the outlets failed. I had my computer plugged into one of the outlets on that wall, and when I pushed the reset, the computer went out. Never did plug in the AC.
Old 07-31-2013, 03:51 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
Both those breaker are on. I'm not sure what the problem is.
If you pressed the TEST button the GFI should have tripped and anything that is fed from the LOAD side of it should have gone off.
Pushing the RESET button should have put everything back to normal.
None of this would have affected the breakers in the panel.
The Following User Says Thank You to Speedy Petey For This Useful Post:
Old 07-31-2013, 04:39 PM   #5
Rewards Points: 150
Pushing the reset button in will shut power off until you let it back out.
In this video, I'm pushing the reset on the gfi and it shuts off the light until I let go of it. They all do that. http://youtu.be/hbE7dUrYfRQ
romex1220 is offline   Reply With Quote
The Following User Says Thank You to romex1220 For This Useful Post:
Old 07-31-2013, 04:57 PM   #6
MarginallyQualified
Rewards Points: 2,464
These are NOT switches. These are breakers.
Do you use them for any sort of daily on/off purpose?
The Following User Says Thank You to TarheelTerp For This Useful Post:
Old 07-31-2013, 04:57 PM   #7
Rewards Points: 14,014
Are you a renter or do you own this home?
Anytime I see Stab Loc on a panel I think Federal panel. What brand does it say on the panel?
http://inspectapedia.com/fpe/fpepanel.htm
Old 07-31-2013, 05:04 PM   #8
StabLoc is FPE.
Old 07-31-2013, 05:27 PM   #9
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Those receptacles shouldn't be on a 30 amp breaker anyway.
wirenut1110 is offline   Reply With Quote
The Following User Says Thank You to wirenut1110 For This Useful Post:
Old 07-31-2013, 05:36 PM   #10
Rewards Points: 150
It's not like the fpe breakers would trip anyway. You should have power to your plugs if all you did was push the reset button. Power is restored when you let the reset button come back out to its normal position
Old 07-31-2013, 10:12 PM   #11
They must not be explaining it right.
That 2-pole 30 has to be for central air or something.
Old 08-02-2013, 07:17 AM   #12
Rewards Points: 323
It was a faulty GFCI. Not only was the test button stuck in position, but the reset button doesn't restore power. So I learned that it has nothing to do with the two breakers, which are for my AC 15,000 BTU window unit, and the breakers are both on after all (optical illusion with the word "on" written only on one of them). The breaker panel is a Federal Pacific. Is that good or bad? I own the house. Whoever put the GFCI in didn't tell me what it was for or how it worked, but now I know, thanks to you all.
Old 08-02-2013, 08:13 AM   #13
Rewards Points: 6,652
Look closer at the bottom of the panel, below the A/C breaker.
Old 08-02-2013, 10:19 AM   #14
Rewards Points: 323
the recessed breaker?
It looks like a recessed breaker below the AC breaker, at the bottom of the panel. I have no idea what that is or why it's like that, just that it doesn't look right. Would you like to shed some light on it? I need all the help I can get with this old house.
Old 08-02-2013, 12:09 PM   #15
MarginallyQualified
It looks like a recessed breaker below the AC breaker..
It's not 'recessed'...
it's not mounted to the bus bar (inside) properly
(here's a LINK to what should be there)
Cutting to the chase... it's time for a new panel.
And very likely some other electrical work around there.
The Following 2 Users Say Thank You to TarheelTerp For This Useful Post:
DIherself (08-03-2013), gregzoll (08-02-2013)
GFCI after dimmer switch curiousB Electrical 16 04-08-2013 04:18 PM
Refrigerator Electrocuted Me. Culprit? lmark103 Electrical 27 12-09-2012 09:18 AM
Replacing kitchen gfci with gfci breakers-something's not right Fpbaum Electrical 14 05-01-2012 08:43 AM
GFCI - White & Black Both HOT? hagler Electrical 11 03-19-2012 08:29 AM
GFCI Question Mdbuilder Electrical 6 06-19-2008 03:15 PM
