Old 12-14-2010, 03:11 PM   #1
GFCI circuit resets but does not work
I've had problems with one circuit breaker in my breaker panel. It has a test button so I believe it is called a CFCI type. This circuit is for the outlets in the 3 bathrooms and an outside receptacle. Any time I try to use the outside receptacle the breaker trips. I can reset it but eventually it will pop again when I use that outlet. Finally it got to a point where it would not reset. Now it looks OK (no need to reset) but the whole circuit is dead. I've removed the outlet outside and capped each wire with a wire twist but the circuit is still dead. It seems to reset, it just does not work. Do you think the breaker needs to be replaced? Any other suggestions?
Alexlonebear is offline   Reply With Quote
Old 12-14-2010, 03:29 PM   #2
Electrical Contractor
Breakers, like gfci breaker can only last so long.
You may have 2 problems, a bad breaker, and maybe a loose or bad connection somewhere in that circuit.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 12-15-2010, 10:20 AM   #3
Thank you for the info. I think I'll start with the breaker and then see what is up with the circuit. One other question. What I said I did about taking the outside outlet out of the circuit. Should that be OK to take care of any problems it might of caused?
(I don't use it much anyway but the outlets in the bathrooms are definitely in use.)
Thanks again
Hank
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
GFCI Outlet on 20A garage circuit campos202 Electrical 2 09-10-2009 10:38 AM
Can a GFCI protected light be installed into a normal light circuit? boongywoongy Electrical 6 05-19-2008 09:02 PM
wiring a gfci outlet in circuit bobo Electrical 12 08-31-2005 09:38 PM
