GFCI Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 03-27-2009, 09:46 AM   #1
GFCI Circuit
I have a friend buying a new home and the GFCI protection is on the garage door opener circuit. Which seems odd to me.
When he questioned the builder he was told that it's a new code that started Jan - 2009, the builder also stated that he questioned the electrician and the electrician showed him documentation on this new code. Are there in electricians out there that can give some feed back?
Thanks in advance
as2637 is offline   Reply With Quote
Old 03-27-2009, 10:06 AM   #2
Yup, that's the new code
I'm putting a GFCI at a lower level, then feeding off the load to a normal outlet near the opener. That way if it kicks off I can reset it easier
Old 03-27-2009, 10:47 AM   #3
dSilanskas's Avatar
Its over kill if you ask me. If something isnt GFCI its AFCI.
dSilanskas is offline   Reply With Quote
Old 03-27-2009, 11:23 AM   #4
I'd think the capacitance from the motor windings to the motor shell would give you enough reactive leakage current to give false trips on the GFCI.
Old 03-27-2009, 12:28 PM   #5
Yeah, we'll see how many problems this causes
I already have 2 older lamps that do not seem to work on an AFCI circuit. I'm going to check them & make sure there aren't any loose wires.
I guess if the AFCI prevents some fires its worth it in the long run
But motors are a whole different ball game
I know there are problems with some vacuum cleaners on AFCI
The problem is if there are enough problems/false trips then people will distrust them & remove them. I know people who will still not install GFCI's
Old 03-27-2009, 01:49 PM   #6
FWIW,
having no circuit breaker in a line will probably eventually cause a fire, and CBs cost $20 or so, so you get a lot of safety for this $20.
BTW, the chance of a house fire per year from any cause is probably 1 in 1000 so this hazard is kind of Down In The Noise, to begin with.
Now comes an AFCI which adds some small increment of safety, maybe worth an additional dollar out of the $20 for a CB. But AFCIs cost a bit more than $1, and I haven't been able to get data on how much extra incremental safety you get by using one of these.
I don't believe it is twice as much as you get from using a breaker.
Even insurance companies charge you less for the last $100K worth of insurance than for the first $100K worth.
The Law of Diminishing Returns doesn't seem to apply to the makers of some of these hi-tech gadgets.
Old 03-27-2009, 03:09 PM   #7
They don't have diminishing returns
The Mfg's are making more $$ with these new requirements
Cost of outlets have gone up - Tamper proof & weather resistant required, AFCI circuits expanded. They make more $$
Old 03-27-2009, 03:14 PM   #8
our garage door is on a gfci circuit and our house was built 3 years ago. I came home one night from work and the x-mas lights had tripped the gfci. Garage door won't open. I didn't have a key to the front door as I always use the garage door opener. yeah I was stuck outside for awhile till the wife got home.
jeerme is offline   Reply With Quote
Old 03-27-2009, 03:16 PM   #9
That's why I have 8 dedicated outside circuits just for Christmas lights. More will be going in now that the garage is up
Old 03-27-2009, 03:41 PM   #10
That's kind of my point.
If the consumer is forced to buy these things
then the companies that make them should also be forced to charge a price for them that is in keeping with the additional safety, if any,
that the consumer is buying.
GFCI for the Lamp Post (GFCI for circuit that is fed Power from light) jamiedolan Electrical 7 02-25-2009 10:50 PM
Gfci Circuit howard.wheaton Electrical 10 01-29-2009 05:14 PM
new gfci on new circuit pops rtoni Electrical 39 11-15-2008 10:18 AM
20A GFCI on 15A circuit jheavner Electrical 35 10-16-2008 03:45 PM
GFCI and Smoke alarm circuit issues 00u6166 Electrical 9 10-30-2007 02:41 PM
