Which GFCI To Buy? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-13-2011, 12:12 PM   #1
which GFCI to buy?
I just removed the GFCI that produced smoke when I pressed the test button. It is a 15 amp GFCI. The circuit breaker to the GFCI says 20 amp. My house was built 10 years ago.
Which new GFCI should I buy? 15 amp or 20 amp?
mike932 is offline   Reply With Quote
Old 05-13-2011, 12:36 PM   #2
Licensed electrician
Rewards Points: 1,750
The only difference is the 20 amp has a T shaped slot. The 15 amp will be fine. You probably can't find a device that requires the T slot in your house.
mike932 (05-13-2011)
Old 05-13-2011, 02:56 PM   #3
So I just replaced the GFCI with a new one. I turned on the circuit breaker. GFCI does not work. I tested all of the wires and there is no charge at all.
What do I do now? Replace the circuit breaker switch?
Old 05-13-2011, 03:04 PM   #4
the Musigician
DangerMouse's Avatar
Did you hit the "reset" button? Being it's new, you have to do that the first time to 'start' it.
DM.
Old 05-13-2011, 03:06 PM   #5
DM.
Yes I did. The problem is no longer the GFCI. The problem is that the power wire is dead. I tested the wire.
Old 05-13-2011, 03:09 PM   #6
the Musigician
You already said the next step then!
(disconnect power first, of course)
DM
Old 05-13-2011, 03:10 PM   #7
Ok, I will replace the circuit breaker switch. Thank you.
Old 05-13-2011, 03:11 PM   #8
The circuit breaker may just need to be reset.
Old 05-13-2011, 03:15 PM   #9
How do I reset the breaker? Just turn the MAIN breaker switch off and on?
Old 05-13-2011, 03:21 PM   #10
the Musigician
No, I don't think he caught the part where you said you turned it back on is all.
IF the breaker STAYED turned on, and the outlets do not work, there is most likely an open in the line somewhere.
If the breaker shuts itself off, there is a short.
DM
Old 05-13-2011, 03:25 PM   #11
When I turn the breaker to the on position, it stays that way even though there is no power from it. In fact, when the old GFCI failed last week and produced smoke, none of the circuit breakers switched off by itself.
Does "open in the line" mean the line is interrupted?
Old 05-13-2011, 03:32 PM   #12
the Musigician
Did you test the breaker with a meter?
If it failed, replace it.
DM
Old 05-13-2011, 03:34 PM   #13
Ok, I will test the breaker. Thank you.
Old 05-13-2011, 03:39 PM   #14
Is this video good advice?
Old 05-13-2011, 03:56 PM   #15
the Musigician
I'm on dialup, can't watch videos, sorry.
DM
Freezer tripping GFCI davidclements Appliances 58 07-03-2015 05:46 AM
Pond pumps tripping GFCI lendosky Electrical 23 12-23-2010 03:22 PM
GFCI Stumper ksqrdks Electrical 2 04-03-2010 06:24 AM
GFCI Question Mdbuilder Electrical 6 06-19-2008 03:15 PM
GFCI questions 5circles Electrical 4 11-05-2007 08:24 PM
