GFCI Breaker Trips When Any Light Is Turned On - Electrical - DIY Chatroom Home Improvement Forum
Old 06-01-2011, 08:31 PM   #1
GFCI Breaker Trips when any light is turned on
I've got a branch circuit that has started tripping the gfci breaker any time a light is turned on, here's what I know.
  1. The house is about 2 years old, the circuit has been working until yesterday
  2. The circuit covers two outlets, two separately switched light fixtures and an exhaust fan in a bathroom plus 3 outlets and two separately switched ceiling lights in the hall area.
  3. I've swapped the hot and neutral wires with another bathroom gfci breaker and the problem follows this circuit
  4. With no load on the circuit the breaker doesn't trip and I can measure voltage at all receptacles and light switches.
  5. As soon as any light switch is turned on, the light flashes and the breaker trips. Additionally, I can take a small lamp and plug it into any receptacle and it will also flash on and then trip the breaker.
Any ideas regarding troubleshooting steps?
Thanks!
rexnance is offline   Reply With Quote
Old 06-01-2011, 08:39 PM   #2
joed's Avatar
Rewards Points: 13,732
Sounds like a ground wire may be in contact with a neutral somewhere. Try splitting the circuit in sections and isolate which section has the problem.
Old 06-02-2011, 08:18 AM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
Is it a gfci, or an afci?
The troubleshooting will be the same either way.
jbfan is online now   Reply With Quote
Old 06-03-2011, 09:55 AM   #4
Not sure if i'ts a combo afci / gfci. I did find the issues in a light can where the ground wire was touching the common leg. Not sure how these things move over time but it clearly did.
Thanks for your help!
Circuit Breaker that trips slowly dmoore Electrical 15 09-07-2010 06:25 PM
Circuit Breaker trips when I plug into an outlet Alex in Orlando Electrical 3 09-05-2010 01:04 AM
900W and up trips breaker, Circuit draws power even with everything off... jasonblu Electrical 40 12-09-2009 02:29 PM
GFCI intermittent nuisance trips jejm1975 Electrical 43 09-07-2008 09:18 AM
New GFCI Breaker trips with no load bmurphywa Electrical 6 04-06-2008 08:48 PM
