GFCI Breaker Trips Randomly - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 09-16-2009, 04:07 PM   #31
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Bimmer, This is NOT causing your GFCI problem
But give those wire-nuts some more twists
GFCI breaker trips randomly-wire-nut-9-09.jpg   GFCI breaker trips randomly-wire-nut.jpg
Disclaimer
& Stay Safe
.....Bob Lavery
Old 09-16-2009, 06:50 PM   #32
randomly tripping GFCI
Another thing to check is the romex staples. As with the clamps, if a staple is driven in to hard it could cause the breaker to trip. You could remove the GFCI breaker replace it with a regular breaker. Remove the recpt. and replace it with a 20 amp GFCI recpt. Just a thought.
rkess is offline   Reply With Quote
Old 09-17-2009, 11:43 AM   #33
Thumbs up
(Elusive cause of) GFCI Breaker trip, Cont'd.
Yes. But (IMHO) the reason for the INTERMITTENT nature of the breaker trip is a moisture condition somewhere. A regular short or ground fault would cause the breaker to trip with great fanfare (Lots of fireworks and noise)! (No matter what)Don't Drink and Drive, Ever!!!
spark plug is offline   Reply With Quote
Old 09-17-2009, 11:47 AM   #34
Rewards Points: 109
Could it be moisture condition near the panel which would only effect the GFCI breaker?
BimmerRacer is offline   Reply With Quote
Old 09-17-2009, 11:52 AM   #35
Licensed Pro
Since it is a GFCI breaker, contact between the neutral and ground will cause a trip with no "fanfare" whatsoever. Moisture, metal expansion, vibration could all cause random tripping if the wires are very close together or a clamp has cut into the insulation.
Old 09-21-2009, 10:03 AM   #36
Rewards Points: 109
well, I didnt get a chance to look at anything this past weekend, but the breaker hasn't tripped since I started this thread.
Old 09-21-2009, 11:10 AM   #37
I'd put a milliammeter in series with a 1/16th A fuse in series with the ground lead from the busbar to see how close you are to tripping.
90' of Romex will normally give you 0.5 mA due to capacitive coupling. If you have 3 or 4 mA there is probably a problem that hasn't yet tripped the GFCI.
Old 09-21-2009, 11:13 AM   #38
Rewards Points: 109
1/16A? where would I get that?
Old 09-21-2009, 01:36 PM   #39
Possibly Radio Shack.
If you're on the 200 mA scale the meter's internal fuse might be 500 mA. You want a series fuse small enough that it trips instead of your meter's internal fuse.
The other way is to measure the cold resistance of a 4w or 7-1/2w 120v incand. lamp and use this as a current sensing resistor, in series with the ground lead.
If the lamp filament reads 100 ohms and the voltage across it is 0.4v then 4 mA is passing through the ground lead.
But always start with your meter set on the highest voltage or current scale.
Old 09-21-2009, 01:46 PM   #40
Rewards Points: 109
Old 09-21-2009, 02:11 PM   #41
My pleasure. Good luck.
20 amp GFCI breaker pops when pool pump is turned on. jagrunner Electrical 11 03-19-2010 04:31 PM
New GFCI Breaker Tripping w/ 3-way Flourescents BigJimmy Electrical 8 12-29-2008 02:29 PM
GFCI intermittent nuisance trips jejm1975 Electrical 43 09-07-2008 09:18 AM
New GFCI Breaker trips with no load bmurphywa Electrical 6 04-06-2008 08:48 PM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
