Gfci Breaker Not Resetting - Electrical - DIY Chatroom Home Improvement Forum
Old 02-15-2013, 09:31 AM   #1
Gfci breaker not resetting
I have a gfci breaker that is wired to three different bathrooms. The circuit feeds only the receptacles. I push the test button the breaker flips to the off position. I wait a few minutes and it will not flip back on. It is jammed. I will then hit the main and then the gfci breaker will allow me to flip it to the on position. Is this normal operation? It never trips on its own, have had no trouble with it in the last 35 years. This was the first time I actually hit the test button so I have no idea what normal is.
paintdrying is offline   Reply With Quote
Old 02-15-2013, 10:54 AM   #2
Rewards Points: 240
The breaker should trip on test and reset with the handle. If it does not do that, it should be replaced.
Old 02-15-2013, 11:08 AM   #3
MarginallyQualified
Rewards Points: 2,464
I pushed the test button the breaker flips to the off position.
Still... be prepared to have a fault to deal with too.
Old 02-15-2013, 11:24 AM   #4
I would say that there's a neutral to ground fault somewhere gfci are really sensitive to this kind of faults and to Me it seems like the gfci is working properly
RAUL HIDALGO is offline   Reply With Quote
Old 02-15-2013, 01:03 PM   #5
Electrical Enthusiast
Rewards Points: 504
What brand of breaker do you have?
Did you try moving it to "extreme" off before resetting?
Some of these breakers have move into a "mid-position" when they trip.
Kyle_in_rure is offline   Reply With Quote
GFCI Breaker W0rter Electrical 4 01-10-2013 04:17 PM
Dimming lights on one circuit, GFCI breaker tripped boatman537 Electrical 4 06-05-2012 10:43 AM
GFCI Breaker Gzuber Electrical 7 05-30-2012 10:38 PM
GFCI Breaker & GFCI Outlet together??? abinpa General DIY Discussions 6 04-12-2009 08:59 PM
GFCI Recepticle vs. Breaker WaldenL Electrical 19 01-18-2009 12:04 PM
