GFCI Breaker On Branched Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 11-08-2012, 07:08 PM   #1
Fire Hazard
GFCI Breaker on Branched Circuit
Hey guys, hope y'all can help...
I have a house with (essentially) 3 outside loads (?): 2 outlets and 1 garage (with lighting, receptacle, etc.). The wiring comes from a single line from the panel to a junction box in the basement, where the line splits to go to the 3 destinations (loads?).
There was no GFCI, so I installed a GFCI breaker. However, it never sets; it trips instantly. I couldn't find any problems in the wiring, so I am wondering if I need to have everything on that line be wired in series for the GFCI to work properly (rather than having it branched like it is) .
I hope I have described this clearly. Let me know, if not.
Thanks in advance,
- Mike
Portland, OR
Superchunk is offline   Reply With Quote
Old 11-08-2012, 07:11 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
The neutral from the branch circuit needs to land on the GFCI breaker, not the neutral bar. The white pigtail needs to be landed on the neutral bar.
Old 11-08-2012, 07:17 PM   #3
Fire Hazard
Thanks for the quick reply, k_buz.
I will double check that I wired that part correctly this weekend, when I give it another try. It was several weeks ago when I tried this, so I'm not sure whether I did it right.
To clarify though...
the branching aspect (or splitting, or T'ing, or whatever) shouldn't matter?
- Mike
[k_buz: Where are you in SE Wisconsin? That's where I'm from originally. ]
Old 11-08-2012, 09:40 PM   #4
k_buz's Avatar
Just north of Milwaukee.
Did My GFCI Circuit Breaker Fail? Jazan Electrical 8 08-04-2012 03:44 PM
GFCI wiring for a jetted bathtub couchpotato Electrical 13 03-20-2012 11:26 AM
GFCI as part of light circuit? iceracer Electrical 5 07-05-2011 08:05 PM
Whirlpool GFCI circuit info conflict. 3detailer Electrical 29 05-17-2010 09:12 AM
Can I replace a breaker w/ gfci myself secutanudu Electrical 12 07-28-2009 11:41 AM
