GFCI Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 06-12-2010, 08:19 AM   #1
Knows everything but that
Rewards Points: 150
GFCI Breaker
Are there any issues with using a GFCI breaker (not outlet) on a multiple branch circuit? I have several other outlets and lights along with a fan above a shower that requires a GFCI circuit. Thank ya!
Shane
JakAHearts is offline   Reply With Quote
Old 06-12-2010, 08:33 AM   #2
Licensed electrician
Rewards Points: 1,764
Could you define your "multiple branch circuit'? If you are asking about a circuit that just feeds multiple lights and receptacles there is no problem. If you are asking about use on a multi-wire branch circuit, there are issues.
Old 06-12-2010, 09:18 AM   #3
Rewards Points: 150
It is one 14-2 going to a junction box and then 3 14-2 coming out. One goes to the fan, one to a switch for lights and one to a row of outlets.
Old 06-12-2010, 09:23 AM   #4
Just call me Andrew
Rewards Points: 1,020
No problem with that at all.
But none of those outlets are allowed to be in the bathroom.
Andrew
secutanudu is offline   Reply With Quote
The Following User Says Thank You to secutanudu For This Useful Post:
JakAHearts (06-12-2010)
Old 06-12-2010, 09:32 AM   #5
Rewards Points: 150
Nope, none of them are. I ran a dedicated circuit for bathroom outlets w/ a gfci outlet. Thanks! You guys are the best.
Shane
Old 06-12-2010, 09:52 AM   #6
Just to clarify
A multiple wire branch circuit (MWBC) is 2 hots, a shared neutral & ground
Its 2 circuits but considered one due to the shared neutral/ground
So to use a GFCI breaker you must use a 2 pole (240v) GFCI breaker
Using one reg breaker & GFCI breaker will cause issues
What you are describing is not a MWBC
So describing it as a multi-branch circuit is a little off on terminology
A bathroom circuit can supply outlets in multiple bathrooms
OR
All lights & outlets in ONE bathroom
The Following User Says Thank You to Scuba_Dave For This Useful Post:
Old 06-12-2010, 10:12 AM   #7
Rewards Points: 150
Originally Posted by Scuba_Dave View Post
Just to clarify
OR
Gotcha, sorry about the wrong terminology.
Old 06-12-2010, 10:15 AM   #8
Just call me Andrew
Don't let it happen again!!!
Andrew
20 amp GFCI breaker pops when pool pump is turned on. jagrunner Electrical 11 03-19-2010 04:31 PM
New Fluorescent Ballast trips GFCI Breaker?? marc515 Electrical 7 02-18-2010 04:42 PM
New GFCI Breaker Tripping w/ 3-way Flourescents BigJimmy Electrical 8 12-29-2008 02:29 PM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
