GFCI Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 11-09-2009, 03:50 PM   #1
GFCI breaker
The pump for my new pond ran dry for 2 seconds and the GFCI breaker in the house tripped now the receptical will not read 110 volts thru the slots in the receptical but i get voltage on the hot side and the ground. I reset the breaker and let it cool down. Now what?
jasnor is offline   Reply With Quote
Old 11-09-2009, 04:30 PM   #2
Residential Contractor
You probably have a loose or broken neutral.
You said it's a GFCI breaker. Do you know if the receptacle you are having trouble with is the ONLY one powered by that breaker?
Edit-by breaker I mean is it in the service panel?
rselectric1 is offline   Reply With Quote
Old 11-09-2009, 10:00 PM   #3
gfci breaker
yes it is the only receptical on this breaker. by the way it seems to be working now after being shut off for about 1 hour. i'll check the neutral to see if it's ok thanks
20 amp GFCI breaker pops when pool pump is turned on. jagrunner Electrical 11 03-19-2010 04:31 PM
GFCI breaker trips randomly BimmerRacer Electrical 40 09-21-2009 02:11 PM
New GFCI Breaker Tripping w/ 3-way Flourescents BigJimmy Electrical 8 12-29-2008 02:29 PM
How to connect switch to GFCI breaker? firemanter Electrical 3 10-28-2008 07:46 PM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
