GFCI In The Bathroom Trouble - Electrical - DIY Chatroom Home Improvement Forum
Old 01-23-2010, 10:42 PM   #1
Rewards Points: 150
GFCI in the bathroom trouble
Hello All,
Another electrical question, this one comes from the up stairs bathroom.
I am going to take some pictures, but the camera rechargeable battery is charging, will get some pictures up soon.
The way the bathroom is laid out and I may been incorrect here but they way I think it lays out.
When facing the bathroom an outlet on the right hand side (closest outlet to the Service Panel) is where the power comes into the room from the 20 amp breaker.
The GFCI outlet then travels about 6 feet to another outlet (changing it out because the outlet was not GFCI just a normal outlet)
Has Black and White coming in and black and white going out
Above the two sinks there is a light, that I was going to replace anyways, but I will bring this up a little later.
Went to the store and bought a GFCI outlet installed to what I thought was correct, turned power back on and the little green light in the right hand corner of the outlet was on, but not power.
Went back to the original outlet I wrote about it has power go to the one I just replaced no power, so I checked the black and white wires with my tester and the power coming in was hot but the second set of black and white wires leaving the outlet was no power
To try and figure out was going on I turned the power on to the light and it was dead and then turned the power on to the fan it was dead too
I turned the power back off checked everything, while the power was on and off I tried to reset the GFI and still nothing.
Took the standard outlet and hooked it back up and the system was back to normal.
Any idea where I messed up here, I have replaced other outlets before with out a problem.
Is there something special to GFI's that I do not know about or messed up on
I did not mention but there was also a ground wire and hooked that up too
Thanks in advance.
canyonbc is offline   Reply With Quote
Old 01-23-2010, 10:54 PM   #2
Only 1 GFCI is needed
Power goes to the LINE side of the GFCI
Other outlets are then protected off the LOAD side of the GFCI
A GFCI will only reset when there is power to the GFCI
Old 01-23-2010, 10:55 PM   #3
Don't think I'm talking down to you, but you pushed the 'reset' button on the gfi after you installed it right?
djlazar is offline   Reply With Quote
Old 01-23-2010, 11:53 PM   #4
Go back to just a regular receptacle there. The GFCI in place covers everything on the load side of it!
Paelectrican is offline   Reply With Quote
Old 01-24-2010, 12:16 AM   #5
Thumbs up
...And the way to test if the "Regular" outlet is downstream of a GFCI receptacle --and protected by it-- is, to "plug" a pigtail socket in the HOT and GROUND pins. If it trips out the GFCI, you're protected and nothing further needs to be done, or can be done!!
spark plug is offline   Reply With Quote
Old 01-26-2010, 03:35 AM   #6
Rewards Points: 150
No way, well good to know. Guess I was doing something was not needed.
Thank you for the info.
Old 01-26-2010, 03:36 AM   #7
Rewards Points: 150
No, I do not see it that way. But yes I did push it.
Old 01-26-2010, 03:36 AM   #8
Rewards Points: 150
I went back to the normal one and that was before I knew all this info.
Thanks all
Bathroom lighting on GFCI? TReally Electrical 7 10-22-2009 12:05 AM
Bathroom Remodel GFCI Receptacle Lilshaving Electrical 4 02-24-2008 11:07 AM
Best way to wire this Bathroom? GFCI, Drawing inside twilightcall Electrical 31 01-21-2008 10:29 AM
Bathroom Vanity Lights... after GFCI? CuCullin Electrical 4 11-12-2007 04:16 PM
Extending a GFCI in the bathroom diamondking Electrical 10 05-01-2007 06:48 PM
