Gfci In Bathroom - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-03-2011, 08:42 PM   #16
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
Originally Posted by The Deez View Post
good lead on that though, what if the the black and white are reversed? in other words maybe the black is white and the white is hot :D i have seen this before, people reversing polarity. I would say this is the best bet, try the white wire on the brass screw and the black on the silver,
A newer GFI, if wired reversed, will NOT let power through, just like he described in post #1.
Old 05-03-2011, 08:42 PM   #17
he said there is a ground, i don't think it's a two wire system
No, he said he grounded it to the box.
Old 05-03-2011, 08:45 PM   #18
Rewards Points: 506
"ground to box and ground lead". Maybe OP needs to confirm.
jlmran is offline   Reply With Quote
Old 05-03-2011, 08:45 PM   #19
Rewards Points: 6,652
Originally Posted by jlmran View Post
What?
What were you asking? See Speedy's reply, because it is line to what I was implying. Most inspecters, especially home inspectors are not worth the trouble to open the door. Now days, you have too many inspectors that were contractors, that think because they used a hammer & saw, or a pair of dykes, think they know everything about inspection. Even when I was in the Navy, it took continuous training to be up to date on everything. A couple of us spent a week learning about various ways to do our jobs better, but even the instructors stated that they could not teach everything in one week, that it could take a year, and still not know everything about everything with Electrical. It is an on going process, because people learn better/safer techniques, and the process changes, because the laws change locally & nationally to make dwellings safer.
Old 05-03-2011, 08:46 PM   #20
Rewards Points: 506
Got it. I thought you meant the posters were complaining.
Old 05-03-2011, 08:49 PM   #21
I think so. I read that as the lead from the box.
If there is a valid ground present then all bets are off. I have no idea what the problem is.
What he describes is a text book "no ground present" condition.
The Following User Says Thank You to Speedy Petey For This Useful Post:
gregzoll (05-03-2011)
Old 05-03-2011, 08:55 PM   #22
That is the same I am getting. Just enough info to get the basics, but not enough to know the whole story.
Old 05-03-2011, 09:17 PM   #23
hey guys thanks for all the help, it is a three wire system. Just pulled the outlet out to recheck again, and the white IS hot so somewhere some one got a wire lead hooked up to the wrong wire before I got to it, I know for sure that I did check and switched the leads before to try it and the gfci would not reset so i switched it back, but however I neglected to check the voltage at the leads. wow stupid for overlooking that.
700mxzxer is offline   Reply With Quote
Old 05-04-2011, 06:10 PM   #24
licensed electrician
cool! glad you found the problem. if you get the tool i linked in the my previous post it will help you check all your recepticals and maybe you can find where they got reversed
The Deez is offline   Reply With Quote
Whirlpool GFCI circuit info conflict. 3detailer Electrical 29 05-17-2010 09:12 AM
GFCI in the bathroom trouble canyonbc Electrical 7 01-26-2010 02:36 AM
GFCI Trips campbellpt Electrical 28 11-21-2008 03:06 PM
How to connect switch to GFCI breaker? firemanter Electrical 3 10-28-2008 07:46 PM
Bathroom Remodel GFCI Receptacle Lilshaving Electrical 4 02-24-2008 10:07 AM
