#1 |
GFCI-Approved Outlets
Is it true that if you have two outlets in your kitchen, and you install a GFCI outlet in the first box, the wire that jumps from that outlet to the second one (if the circuit ends there) will make the second outlet GFCI protected too? The guy that works the electrical dept at Lowes told me that, he said i didnt need to buy two GFCI outlets for my kitchen because the wire running between them would protect them both since the two are on a dedicated circuit
#2 |
Electrical Contractor
Yes, if it is wired correctly.
Connect the wire from the panel to the line side, and the wire feeding the 2nd receptacle connected to the load side.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett" |
#3 |
And whatever else the 2nd outlet connects to as well (if anything).
Note that it is common for electric motors to "leak" a bit of electricity to ground. And refrigerators have electric motors in them. So you may not want to do that if the refrigerator outlet is "downstream" from the GFCI outlet. (Or you may come home after being away several days and find all your food spoiled because the GFCI turned off power to the refrigerator.) Also I think it would be a LOT less frustrating to homeowners if a separate GFCI was installed at each outlet or GFCI breakers were used. Power goes out to a regular looking outlet, then the homeowner checks the breaker and it is fine. Then the "hunt" begins to find that GFCI outlet. In the case of a garage, the GFCI outlet is probably behind a large pile of junk!
#4 | |
I found this summary of Kitchen counter top electrical requirements which may put your GFCI question into a broader context.
#5 |
there are six total receptacles in the kitchen area. One under the window in the dining area, one behind the stove, two over the countertop, one over a small countertop next to the stove, and one for the refrigerator. The two over the sink counter are on a dedicated circuit, the fridge is on a dedicated circuit, and the rest are all on one circuit with the light. If i put a GFCI in one outlet over the sink, then both of those would be protected and thats all that is required, right? the ones by the stove, fridge, and dining room arent near any water so they shouldnt be GFCI required
#6 | |
GFCI-Approved OutletsQuote:
#7 |
its not legal to have three receptacles and a light on one circuit? Since when? Even my bedroom is that way, its all on one circuit. THe plug behind the stove is for the stove clock, the 220 plug is coming up through the floor. the others are just normal receptacles wired with 12/2 romex.
by the way, thats factory. The only electric that wont be factory in this trailer is some that the previous owner added for an outdoor addition of some sort, and the dryer and stove plug that i will have to add since someone stole mine Last edited by firsttimeremode; 09-18-2012 at 02:07 PM. |
#8 | |
Lic Electrical Inspector
All responses based on the 2011 NEC. If you live in New Jersey click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . All other states click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Please check with local, county and state officials as laws may vary. Sizing motors To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online motor calculator To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online calculators To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . |
#9 |
oh well, they work and the builders thought it was good enough, so it works for me. i do not intend to rip out any paneling that i dont have to, and as far as i can see only one panel needs pulled off, and hopefully we can put it back after repairs are made.
#10 |
Master Electrician
If your just changing devices you don't have to redo wiring. Although it is a good idea
Sarcasm is my friend I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own. |
#11 | |
" Euro " electrician
I know few moble home done that like that fashion as you describing but that is on older than 1990 after 1990 they ran it seperated. And be aware that with stove and dryer plugs on mobile home always be 4 wire format so they will be differnt than common 3 wire recpetales for stove et dryers. Merci, Marc
The answer will be based on NEC ( National Electrical code ) or CEC ( Cananda Electrical code ) or ECF ( Electrique Code France ) |
#12 |
i use the normal receptacles for dryer and stove that come up through the floor. Its the same as it was in every other trailer ive ever been in. And yes, it is a lot older than 1990, its a 1979
#13 |
One shock danger of using handheld electrical appliances is using them near something which is metal and grounded. Like a sink, water faucet, or kitchen range are likely to be grounded.
And then you use a handheld appliance which is shocking you due to a malfunction and at the same time touch a grounded metal part with the other hand. So that could happen as well with a kitchen range. I would recommend installing a GFCI there as well. You can install it so just that outlet is GFCI protected or install it so anything "downstream" from that is protected too. Also be sure your wiring is copper. If it is aluminum, ask here what to do. And you may not be "required" to do anything if no GFCI's were installed when the home was manufactured. But new electrical code requirements are a VERY good thing in that they protect you and your family. With that said, I would install GFCI's in any outdoor outlets, bathrooms, and garage (in addition to the kitchen). And especially if you have a garage with a metal garage door and an electric garage door opener - protect the opener outlet with a GFCI. (A small child was electrocuted by touching a metal garage door which had a malfunctioning opener.) Good you are doing this! |
#14 |
When i go to look at a house i want to buy, the first thing i do is i dislodge a receptacle and check the wiring. If its aluminum i wont touch the house. If its copper, i put it back and then have the owner open the panel box so i can check that too.
| Display Modes | |
| GFCI Breakers vs. Outlets | michaelson | Electrical | 2 | 03-23-2012 06:59 PM |
| Landscape wiring question: GFCI and Breaker Amp | MikeInDetroit | Electrical | 0 | 11-02-2011 10:43 AM |
| When I add my GFCI outlets....... | nateshirk | Electrical | 11 | 05-04-2011 10:07 PM |
| Supplemental Outlets in 1950's House | Perry401 | Electrical | 2 | 05-01-2011 09:49 PM |
| Problem with GFCI Outlets in Kitchen | mkrawitz | Electrical | 13 | 04-14-2010 09:35 PM |
