Gfci Alternate Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 02-04-2010, 09:38 AM   #1
gfci alternate wiring
Can you wire a gfci so that downline outlets are not protected?
Thanks-Mac
macddmac is offline   Reply With Quote
Old 02-04-2010, 09:51 AM   #2
Yes, just use "pigtails" and wire nuts sort of like this...
Billy_Bob is offline   Reply With Quote
Old 02-04-2010, 09:54 AM   #3
P.S. Those GFCIs use a lot of space in the electrical box, better to use a large deep electrical box or a separate junction box.
Old 02-04-2010, 10:50 AM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 424
Wire everything to the line side of the gfci.
Old 02-04-2010, 11:14 AM   #5
Just call me Andrew
Rewards Points: 1,020
The "line" side of a GFCI is not protected. Just wire your next outlet off that side along with your incoming power feed. Just make sure you don't wrap two wires around the same screw, not allowed. Some clamp-type outlet screws can hold two wires safely. If yours can't, split the feed with pigtails like Bob suggested, before the GFCI.
Andrew
secutanudu is offline   Reply With Quote
Old 02-04-2010, 10:22 PM   #6
thanks for the advise ya'll
Mac
wiring up a switch from a GFCI Limit54 Electrical 16 02-03-2010 06:10 PM
wiring new GFCI breaker question dgates12 Electrical 8 01-07-2010 12:14 PM
Leviton 8599 GFCI wiring issues Ultrarunner2017 Electrical 4 02-06-2009 08:53 AM
Need GFCI wiring help dlgobeavs Electrical 7 10-01-2008 12:14 PM
wiring a gfci outlet in circuit bobo Electrical 12 08-31-2005 08:38 PM
