Old 11-17-2010, 12:30 AM   #1
gfci
2 outlets connect together in a junction box , if i install a gfci in one of them, is the other outlet protected too? thanks
gefeiora is offline   Reply With Quote
Old 11-17-2010, 12:55 AM   #2
" Euro " electrician
frenchelectrican's Avatar
gfci
It depending on the way it wired on the receptales.
Normally with the GFCI you have to bring the incomming power to line side of GFCI { it will be marked to see which one it is } and the load side that will go to next receptale.
Before you do that turn off the power of that receptales to see what else it is on that circuit.
And how many cables and numbers in the box so we can able give you the correct way to hook up.
Merci.
Marc
Old 11-17-2010, 01:07 AM   #3
Professional Wood Shafter
ryanh's Avatar
gfci
If you feed the second outlet from the load terminals on the first gfci.
ryanh is offline   Reply With Quote
Old 11-17-2010, 10:13 AM   #4
gfci
Could be wired either way.
You can test it without even looking at the wiring.
Plug in a lamp to the non-gfci outlet.
Press the test button. If the light turns off then back on when you hit reset it's gfci protected.
michaelcherr is offline   Reply With Quote
Old 11-17-2010, 02:49 PM   #5
gfci
i understand the principles of the gfci, first line and nest the load, etc. in this case the line that goes to the bathroom,is a junction box that connects 2 outlets and the lights.There is no grounding and thought to install a gfci to protectthe outlets. In the junction box they all connect to line with the power. So there's no first or second.Thanks for the all replies,and thanks again.
Old 11-17-2010, 05:47 PM   #6
Jack of all - master none
hyunelan2's Avatar
gfci
On a related topic, is there a limit to the number of receptacles that can be protected by a single GFCI outlet?
i.e. if you go breaker -> (line side) GFCI (load side) -> outlets 1,2,3... what is the limit? Is it the standard limit for receptacles on the branch, or can a GFCI only adequately protect x number of outlets?
hyunelan2 is offline   Reply With Quote
Old 11-17-2010, 07:10 PM   #7
I=E/R
a7ecorsair's Avatar
gfci
Then GFCI the two outlets and leave the light on the line side.
a7ecorsair is offline   Reply With Quote
Old 11-17-2010, 11:03 PM   #8
gfci
Thanks, for all the information. Another question.How many times you reset the gfci ? They say once a month ? So if happens to have a tv and vcr on that line, you must program tv and vcr every month!!!? thanks
Old 11-18-2010, 12:49 AM   #9
Mad Scientist
gfci
Meh, they say you should test them once a month, but I've never really heard of anyone actually doing it. I know I test 'em when I install them, and generally never again.
McSteve is offline   Reply With Quote
Freezer tripping GFCI davidclements Appliances 40 10-15-2010 11:38 PM
GFCI Stumper ksqrdks Electrical 2 04-03-2010 07:24 AM
new gfci on new circuit pops rtoni Electrical 39 11-15-2008 11:18 AM
GFCI Question Mdbuilder Electrical 6 06-19-2008 04:15 PM
GFCI questions 5circles Electrical 4 11-05-2007 09:24 PM
