GFCI 220 Volt Questions - Electrical - DIY Chatroom Home Improvement Forum
Old 11-28-2012, 09:55 AM   #1
Rewards Points: 79
GFCI 220 volt questions
I am close to ready for my rough in inspection for electricity on my remote mountain property.
I do not know electrical code well enough, especially NEC 2011. I am worried that I will have to pay for another inspection if I am not well prepared.
I have had the trench, and ground rods (2) inspected and passed. The meter box and transformer are in place and wire run from the trench to the workshop.
I have 2 GFCI 20 amp breakers, and plenty of 20 amp GFCI outlets. The lighting circuits are 15 amp and not GFCI.
I have 220volt tools (air compressor, radial saw)20amp, and a 50amp arc welder. I have never seen a 220volt GFCI circuit breaker. I have separate breakers for each of the tools.
Do I need GFCI 220volt breakers and a GFCI 15amp breaker for the lighting?
gobug is offline   Reply With Quote
Old 11-28-2012, 09:58 AM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Not needed.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 11-28-2012, 10:01 AM   #3
TTW
TTW's Avatar
Is this building a garage? Separate from a home on the property?
TTW is offline   Reply With Quote
Old 11-28-2012, 12:05 PM   #4
Rewards Points: 79
It is a garage, separate from the house that burned down prior to my purchase. It will not be used as a garage but a workshop/breakroom. It is 70ft from the transformer and 80ft from the building site. I will convert the old basement into a garage and build the new abode adjacent to the future garage.
Old 11-28-2012, 02:22 PM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 488
You do not need both gfci breakers and receptacles for the 120v.
You could use one or the other.
jbfan is online now   Reply With Quote
Old 11-28-2012, 02:45 PM   #6
Rewards Points: 79
I have the two 110v 20amp GFCI breakers on circuits with 3 regular 2-outlet fixtures each. These are for breakroom appliances (coffee pot, microwave, toaster oven, crockpot, and food processor)
I have separate 110v 20amp GFCI outlets as the first outlet only on circuits with only 1 regular 2-outlet fixture each. These are for electric tools.
I have a separate 110v 20amp circuit with a GFCI outlet for the refrigerator.
Does this sound OK?
GFCI troubleshooting XwpisONOMA Electrical 20 11-13-2011 05:19 PM
GFCI questions tmorriss Electrical 3 04-18-2011 12:15 PM
Gfci Circuit howard.wheaton Electrical 10 01-29-2009 05:14 PM
GFCI Trips campbellpt Electrical 28 11-21-2008 03:06 PM
GFCI questions 5circles Electrical 4 11-05-2007 08:24 PM
