Gfci - Electrical - DIY Chatroom Home Improvement Forum
Old 01-04-2014, 01:50 PM   #1
Gfci
Hello everyone. First post. I am a little confused on code for GFCI. I have finished erecting a metal building (detached) and believe that code says GFCI recepticals. Would GFCI breakers do the same protection for all the recepticals? Am running a 100 sub with 50 amp service. One circuit dedicated for 240 welder. Rest will be 20amp.
Mitch2 is offline   Reply With Quote
Old 01-04-2014, 02:01 PM   #2
Rewards Points: 3,130
GFCI breakers would do the job, though I'm sure they'd be more expensive. If wired correctly, you only need one GFCI receptacle per circuit.
The Following User Says Thank You to md2lgyk For This Useful Post:
Mitch2 (01-04-2014)
Old 01-04-2014, 02:19 PM   #3
Gfci
Would I have to use a GFCI breaker for the lighting circuit(no recepticals) and 1 for a hard wired motor?
Old 01-04-2014, 02:42 PM   #4
Rewards Points: 13,968
Only need then in the outlets..
An outlet would cost about 1/3 as much as a GFI breaker and do the same job.
You'll thank yourself later if you wire the outlets with 12-2 and a 20 amp. breaker.
You can still use 15 amp. outlets.
Old 01-04-2014, 07:24 PM   #5
Gfci
Thanks guys. Just got home from our friendly big box home improvement centers. Checked on the GFCI breakers. WOW!!! anywhere from 40-65$!!! Think I will stick with the outlets.
Old 01-04-2014, 07:30 PM   #6
and you can serve multiple downstream receptacles from the load-side of a single gfci receptacle. you don't need to install a gfci receptacle at every receptacle location.
itsnotrequired is offline   Reply With Quote
The Following User Says Thank You to itsnotrequired For This Useful Post:
joecaption (01-04-2014)
Old 01-04-2014, 08:19 PM   #7
Thumbs up
Gfci
Thanks. I had found that out when replacing problem outlets in kitchen. Opend box covers and found fires waiting to happen. Guess that is for another thread.
Freezer tripping GFCI davidclements Appliances 58 07-03-2015 05:46 AM
GFCI after dimmer switch curiousB Electrical 16 04-08-2013 04:18 PM
Replacing kitchen gfci with gfci breakers-something's not right Fpbaum Electrical 14 05-01-2012 08:43 AM
GFCI - White & Black Both HOT? hagler Electrical 11 03-19-2012 08:29 AM
GFCI Question Mdbuilder Electrical 6 06-19-2008 03:15 PM
