Gfci - Electrical - DIY Chatroom Home Improvement Forum
Old 03-17-2013, 08:31 PM   #1
Rewards Points: 1,046
Gfci
When a GFCI feed another receptacle thru its Load terminal, does that mean this receptacle is protected as well?
If I don't really care for the additional $12, can I feed another GFCI thru the Line terminal of the 1st GFCI? (hope I am clear.....)
french_guy is offline   Reply With Quote
Old 03-17-2013, 08:33 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Any device supplied downstream off the LOAD terminals will be GFCI protected from the original GFCI.
Old 03-17-2013, 08:43 PM   #3
Rewards Points: 6,652
The directions that comes with the device, or the info at the manufacturer website will tell you that info. Pass & Seymour & Leviton have the instruction sheets on their sites.
Old 03-17-2013, 08:45 PM   #4
OK, so the new GFCI I am installing is upstairs
And the one that feeds it is downstairs (I know because it tripped and the one upstairs was not powered...)
So like I said, if I don't care for the additional $12 and prefer to have 1 GFCI in the bathroom upstairs, I should feed it from the one downstairs, making sure ALL wires are on the Line terminal?
Old 03-17-2013, 08:46 PM   #5
Yes, and yes.
Willis
williswires is offline   Reply With Quote
Old 03-17-2013, 08:48 PM   #6
Originally Posted by williswires View Post
Yes, and yes.
So in that case, the additional GFCI must be fed from the Line terminal of the 1st one, right?
Old 03-17-2013, 09:49 PM   #7
Lord of Slums
Rewards Points: 1,974
On the top wiring diagram, http://www.buildmyowncabin.com/elect...i-outlets.html would I have to snap that little bar on the outlet to feed both top and bottom?
mj12 is offline   Reply With Quote
Old 03-17-2013, 10:09 PM   #8
That's a good set of graphics for this discussion.
For the OP, the second graphic shows the 1st GFCI being connected using pigtails instead of feeding through the supply and the outgoing conductors to the 2nd GFCI. That's a good way to do it, although not necessary unless a local ordinance requires it.
You would only snap the bar to separate the top from the bottom, so the answer is no.
BTW, there are NO bars to snap on a GFCI receptacle.
Willis
The Following User Says Thank You to williswires For This Useful Post:
jbfan (03-17-2013)
2 Similar GFCI, but one tests open ground crescere Electrical 40 08-28-2012 10:19 PM
Replacing kitchen gfci with gfci breakers-something's not right Fpbaum Electrical 14 05-01-2012 09:43 AM
GFCI wiring for a jetted bathtub couchpotato Electrical 13 03-20-2012 12:26 PM
GFCI - White & Black Both HOT? hagler Electrical 11 03-19-2012 09:29 AM
GFCI Question Mdbuilder Electrical 6 06-19-2008 04:15 PM
