Gfci - Electrical - DIY Chatroom Home Improvement Forum
Old 01-27-2013, 09:29 PM   #1
gfci
I have been reading about the gfci receptable, and was wondering if I start the gfci plug in a different room would all the plugs on the same circuit be gfci protected. Can a 12/2 circuit be used for gfci? I am finishing my basement with a wet bar and where the wet bar is located if I place the gfci plug around the sink it would not be the first plug on the circuit. Any ideas would be helpful.
kosovofalcon is offline   Reply With Quote
Old 01-27-2013, 10:08 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,904
As long as you feed the downstream receptacles from the "LOAD" terminals on the GFCI, the downstream receptacles will be protected.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 01-27-2013, 11:07 PM   #3
All devices downstream of the gfci will be protected. Can also install a gfi breaker in the panel.
mbryan is offline   Reply With Quote
The Following User Says Thank You to mbryan For This Useful Post:
gregzoll (01-28-2013)
Old 01-28-2013, 04:32 AM   #4
Licensed electrician
Rewards Points: 1,294
Only if wired from the LOAD terminals.
Old 01-28-2013, 06:55 AM   #5
When u say down stream you are meaning main power to gfci then what ever else is dasiy chained after that on the line side. Is that correct. Would a gfci breaker do the same thing as the plug but just in the panel?
Old 01-28-2013, 08:45 AM   #6
joed's Avatar
Rewards Points: 12,026
GFCI breaker would do the same thing for lots more money.
Old 01-28-2013, 08:45 AM   #7
Rewards Points: 6,652
Yes, just a different form of the device. Keep in mind, that your jurisdiction, may require AFCI breakers in a finished basement, so you really need to check with them first, before going further.
As for wiring the basement, how many outlets are we talking all together for just this one 20amp circuit? Also what city & state, or country are we talking about, where you reside?
Old 01-28-2013, 08:47 AM   #8
No more than 8 plugs on the circuit. Reside in fredericksburg va
Old 01-28-2013, 08:59 AM   #9
Here in the U.S., you are not limited to the number of receptacles on a circuit, just the total load. You could have a hundred outlets on a circuit, unless your area specifically spells it out, for the limit.
Old 01-28-2013, 09:07 AM   #10
Freezer tripping GFCI davidclements Appliances 58 07-03-2015 06:46 AM
Another GFCI Question Jzone99 Electrical 5 09-16-2012 02:56 PM
Replacing kitchen gfci with gfci breakers-something's not right Fpbaum Electrical 14 05-01-2012 09:43 AM
GFCI - White & Black Both HOT? hagler Electrical 11 03-19-2012 09:29 AM
GFCI Question Mdbuilder Electrical 6 06-19-2008 04:15 PM
