Old 11-12-2012, 07:57 PM   #1
Gfci
I want to know if I can add a GFCI combo switch from an existing light. This bathroom has no outlets. I was able to put in a regular outlet for the time being. I added wiring from the light to the outlet. I bought the GFCI combo, but am so confused if I can even use it with the existing configuration. The power is coming from the light source. Any thoughts would be appreciated. There are 3 wires, black, white and ground.
jkanketell is offline   Reply With Quote
Old 11-12-2012, 08:14 PM   #2
Electrical Contractor
Gfci
Can not be done without another wire.
Of course I'm guessing that you mean a switch/gfci combo.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
jbfan is online now   Reply With Quote
Old 11-12-2012, 08:31 PM   #3
Gfci
if power is coming from light, u will need the black and white just to switch the light. so if its possible to get another wire down, or a 3 wire ur all set.
wallajon is offline   Reply With Quote
Old 11-12-2012, 08:39 PM   #4
Gfci
So if I can pigtail a black and another white wire it should work? How does that configure for the GFCI? Do I use the switch wires that are attached to the GFCI? I just might have to fork over the dough and get an electritian. I am at my wits end. Thanks for the input, I really appreciate the quick replies guys.
Old 11-12-2012, 08:41 PM   #5
Gfci
Yeah, a switch, GFCI outlet. So, you mean another black and white wire, pigtailed from the light?
Old 11-12-2012, 08:43 PM   #6
Gfci
Just another wire.
What you need is a hot to feed the receptacle and switch, a neutral to feed the receptacle, and a wire to return power to the light when the switch is turned on.
Old 11-12-2012, 08:49 PM   #7
Gfci
So, pigtailing would work? Or a completely new wire connected to the light? Sorry, if I sound like a dunce. I don't give up easliy. I guess how you get the power shouldn't matter. Thank you so much for your quick reply.
Old 11-12-2012, 08:53 PM   #8
Gfci
A new wire to the light fixture.
Old 11-12-2012, 09:14 PM   #9
Gfci
I already added a new wire to the light. So a second one too? Smacks head, yeah I must be a dunce. LOL By wire I mean a 12/2 bundle of black, white, and a ground. thanks
Old 11-12-2012, 10:17 PM   #10
Gfci
You need 3 "conductors" study what jbfan posted
tduncanlu1077 is offline   Reply With Quote
Old 11-12-2012, 10:28 PM   #11
Gfci
are the three conductors name black, white and ground? Please s p e l l it out for me, I am tired of all of the diagrams I have been studying. Thanks.
Old 11-12-2012, 10:35 PM   #12
Gfci
Ok here goes - pull out the 12/2 (easier to explain guys) pull a 12/3- at light u will put "hot" wire on black of the 12/3 - at sw/rec make pigtail on black with 2 ends on it, put one on the sw and one on the rec - put white on rec - put red on sw - at light put red on light's black - put white to white
Old 11-12-2012, 11:23 PM   #13
Gfci
Okay it is getting clearer, sw meaning switch? and rec meaning? thanks
Old 11-13-2012, 08:25 AM   #14
Gfci
Rec meaning receptacle
The Following User Says Thank You to tduncanlu1077 For This Useful Post:
jkanketell (11-13-2012)
Replacing kitchen gfci with gfci breakers-something's not right Fpbaum Electrical 14 05-01-2012 09:43 AM
GFCI wiring for a jetted bathtub couchpotato Electrical 13 03-20-2012 12:26 PM
GFCI - White & Black Both HOT? hagler Electrical 11 03-19-2012 09:29 AM
Freezer tripping GFCI davidclements Appliances 40 10-15-2010 11:38 PM
GFCI Question Mdbuilder Electrical 6 06-19-2008 04:15 PM
