Getting Shocked By Face Plate Screws - Electrical - DIY Chatroom Home Improvement Forum
Old 12-02-2007, 12:03 PM   #1
Getting shocked by face plate screws
Thank you in advance for anyone that can help.
I have recently finished my basement, which I wired myself. All circuits are far less than 80% percent of their capacity, I have can lighting throughout the basement that are connected to dimmer switches. The switches are ganged in the box. There is one 600-watt 3-way dimmer, one 1000 watt dimmer, and one 3-way (left to right). The problem that I am having is that whenever I touch the faceplate screws for any outlet or switch (including non dimmer switches for closet lights), I get an initial shock. If I touch the screw again, I do not get shocked. After walking around the room for awhile, if I touch any of the screws again, I get shocked. This does not happen anywhere else in the house, just the basement. Does anyone have any idea what I can do to fix this. The shock is not painful, is just more of an annoyance than anything because it happens everytime.
vogtage83 is offline   Reply With Quote
Old 12-02-2007, 12:31 PM   #2
Power Gen/RS Engineer
Rewards Points: 566
I hate to even suggest this, but could this possibly be just static electricity? That screw should be grounded which would make a convenient place to discharge to. On the other hand, you could be getting a real shock and if the circuit was protected by a GFCI recept or breaker, perhaps it has tripped which would explain why you only got tagged once. However, this is probably not the case for the following reasons:
1. Lighting circuits are typically not candidates for GFCI protection,
2. If the circuit was tripping, I'm sure you would have noticed that.
Here in the Midwest where it's getting to be winter, the dryer indoor air can attribute to the generation of some hefty body charge which can make for a really nice static jolt.
The best thing to do would be to measure with a meter or wiggy the voltage between the screws and another electrical ground, i.e. the ground hole on a nearby recept just to make sure.
Just a thought,
Jimmy
PS Edit: I noticed that you mentioned outlets as well which I assume you to mean plug/cord receptacles. Based on this, I'd toss the GFCI suspicion and go with the static electricity theory. The floor type in your basement, which may be different from other parts of the house may play a part. Or, if you have a different type of heating system in the basement, i.e. one that does not humidify the air, that could make a difference too.
Well, now, there's what's right and what's right and never the twain shall meet.
Last edited by BigJimmy; 12-02-2007 at 12:35 PM. Reason: Didn't see that the shocks occur at recepts too.
BigJimmy is offline   Reply With Quote
Old 12-02-2007, 01:31 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,876
I find it amazing that after this statement..........
........this is not obvious.
Old 12-02-2007, 02:01 PM   #4
Way to go Pete.
To the OP, put in plastic plates and vinal screws.
Master Electrician
jwhite is offline   Reply With Quote
Old 12-02-2007, 04:32 PM   #5
It is obvious that I thought of static electricity, which is why I mentioned walking around the room. However, I have no other problems in the rest of the house. That is why I was suspicious. I was concerned because we have small children running around and I wouldn't want anyone getting shocked from the plug outlets. If this is just a case of static and dry air, then I like the idea of vinyl screws. Can I pick these up at a local hardware store, or are they a difficult-to-find item? Thanks for the help.
Old 12-02-2007, 05:20 PM   #6
Electrician philosopher
I'd find a buddy with a voltage meter and check it out. That would ease your mind and rule out nefarious electron misdirection in your premises' wiring. Then I'd get vinyl screws and be done with it. Should be at all your fine home centers.
Andy
Andy in ATL is offline   Reply With Quote
Old 12-02-2007, 05:49 PM   #7
Electrician
Andy
C'mon, everyone knows what a static shock feels like...
chris75 is offline   Reply With Quote
Old 12-02-2007, 06:12 PM   #8
I've been known to jump like a little girl if I get hit at just the right moment.
Old 12-02-2007, 06:21 PM   #9
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Best advice I can give is google static electricity and bone up one the ways to prevent it. Point elimination at the wall switches isn't going to stop a shock from occuring at say a metal door knob. Static in a residenence rarely is a safety issue but if it is a large static shock it isn't very funny and could scare the ************ens out of the little ones. So if your getting one of those "gets your attention shocks" I'd be for taking it serious and eliminate the sourse of the static.
If you want we can discuss static and where your problem is likely occuring and help you rid yourself of this nuisance shock.
My best guess is very dry air combined with the type footwear and floor surface your walking on.
Old 12-02-2007, 06:56 PM   #10
Electrician
Add a humidifier to your house heating system...
Old 12-02-2007, 08:41 PM   #11
Custom Cabinet Maker
stop walking on the carpet without shoes :} carpet,socks,motion,dry air: that is a formula for; ZAP!!!!!!!!!!
put your Nikes on and try it again most likely find problem went away :}:}:}:}
skymaster is offline   Reply With Quote
Old 12-02-2007, 09:17 PM   #12
Union Electrician
goose134's Avatar
Here is a video that may help:
Pay close attention to the part about carpets.
goose134 is offline   Reply With Quote
Old 12-02-2007, 11:37 PM   #13
r O F L M F A O
see Told Ya
carpet
Old 12-03-2007, 05:23 AM   #14
Once fried, twice shy.
elkangorito's Avatar
Don't forget about clothes.
Many synthetic fibres can cause a build up of static electricity when rubbed against dissimilar things. Of course, dry air does not help.
Switchboard design engineer & Licensed Electrician (Australia).
elkangorito is offline   Reply With Quote
Old 12-03-2007, 11:04 AM   #15
Rewards Points: 80
Some people think a static charge is nothing but a nuisance, which it is. But I can tell you from experience, I have pulled a 4" mini lightning volt when exiting my fabric car seat. It happens all winter long. It hurts and could cause issues at the gas station.....LOL
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
I can't get tapcon screws to tap into the concrete slab!? Monty Building & Construction 24 08-07-2010 08:08 AM
Adding closet to carpetted room. Sole plate on top of carpet? roysoto Building & Construction 2 09-23-2006 12:01 AM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 06:58 AM
DECK decking nails vs screws ... christian15213 Building & Construction 8 05-02-2005 08:51 PM
