Getting Shocked - Electrical - DIY Chatroom Home Improvement Forum
Old 09-30-2012, 01:17 AM   #1
getting shocked
everytime i flip on any switch in my house we keep gettin shocked can anyone teel me what this might be
propertybrotha is offline   Reply With Quote
Old 09-30-2012, 01:35 AM   #2
Rewards Points: 558
What you are experiencing is a static discharge. Static electricity builds in your body, and is being discharged to the ground. Possible cause include, your carpeting if you have any, your clothing and your footwear.
epson is offline   Reply With Quote
Old 09-30-2012, 02:51 AM   #3
Master Electrician
Or it could actually be a real shock say from a faulty switch. Or worse it could be a ground issue. Saying oh its fine its just static electricity is sort of counter productive from a safety point of view don't you think?
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
The Following 2 Users Say Thank You to andrew79 For This Useful Post:
Code05 (09-30-2012), mpoulton (09-30-2012)
Old 09-30-2012, 09:30 AM   #4
Licensed electrician
Rewards Points: 1,276
Have any wiring changes been made recently? A bootleg neutral could be putting voltage on parts that should be grounded.
Old 09-30-2012, 09:57 AM   #5
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
It's not one switch but every switch in the house.
Odds are it's static electricity.
sublime2 is offline   Reply With Quote
Old 09-30-2012, 11:11 AM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 1,154
Most switches are plastic....unless they are touching the screws....I'm not sure how they could get shocked.
If it is off the screw, then the ground for the light circuit is energized....
Possible troll alert? Go read the OP's other post.
Old 09-30-2012, 08:14 PM   #7
dmxtothemax's Avatar
Rewards Points: 5,106
Are they metal plate switchs or plastic plate switchs ?
If plastic,
it is atatic electricity.
If metal,
could still be static or small currents in earth system.
Use a ac volt meter from the metal plate to the ground (real ground).
Tracking down earth currents will most likely require
the services of an electricain.
as causes & remedies are quite often complex.
dmxtothemax is offline   Reply With Quote
Is being shocked in a properly bonded pool truly impossible or just improbable? LeighB Electrical 36 05-30-2013 01:08 AM
3 way switch (shocked) rcimemphis Electrical 10 09-14-2012 07:17 PM
Getting shocked by face plate screws vogtage83 Electrical 21 12-04-2007 12:55 PM
Getting Shocked!!! dspeh Electrical 4 05-18-2006 02:00 PM
