Getting Shock From Chandelier When Changing Bulb - Electrical - DIY Chatroom Home Improvement Forum
Old 01-31-2013, 09:14 PM   #1
Getting shock from chandelier when changing bulb
Hello, I have a 6 bulb chandelier that takes 60 watt bulbs, it seems like every time I change a bulb I get a minor shock even when the light is turned off at the switch. I would love to fix this problem if at all possible.
Does anyone know what could be the problem and how I can fix it?
I'm pretty much a newbie at doing electrical work but am up to the challenge.
Thanks!
paulgj is offline   Reply With Quote
Old 01-31-2013, 10:15 PM   #2
Missouri Bound's Avatar
Turn off the breaker and check the wiring to the chandelier. You could have a loose nut on the neutral and it is shorting to ground, could be a broken wire...quite a few possibilities.
Do you want it your way or the right way?
Old 01-31-2013, 10:16 PM   #3
MCB
sparky
A shock with the switch off, like a static electricity shock? VERY gently touch your wife on the ear just before you change the bulb.
of course, maybe somebody switched the black and white in the ceiling box. If the light's cords two wires look the same in there, one may have a slight ridge along it. It should be on the white conductor. Check the grounds are solid from the lamp to the ceiling box and there is one from the power wire to the box also. Bond the light to the box.
MCB is offline   Reply With Quote
Old 02-01-2013, 01:14 AM   #4
Rewards Points: 27
The fixture could be switched on the neutral side, and thus ALWAYS hot. The lampholder shells could
be wired to the hot. Frayed wires might be shorting to the metal parts of the fixture, and no effective ground.
All bad stuff. Have a qualified person check it out.
kreemoweet is offline   Reply With Quote
"Final" bulb in parallel circuit brighter than rest. Why? 7.62 Electrical 11 04-30-2012 05:13 PM
need help changing out light bulb gswarriorfan Electrical 13 04-17-2012 09:43 AM
Replacing undercabinet halogen bulb with xenon bulb gabbie14 Electrical 10 09-26-2011 11:46 PM
Dim bulb after changing socket RL2ThDr Electrical 14 10-18-2010 12:30 PM
Changing Bulb Sockets dwa Electrical 3 03-21-2008 03:30 PM
