Getting New Home Runs Into Attic - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-11-2012, 11:35 AM   #16
Thadius856's Avatar
Rewards Points: 504
I think I can get by with adding two 1-1/4 emt for six 12-2 and pulling the 7th thru an existing emt that only has two conductors. This would be tons easier for me. But is it legal?
Anybody know if the CEC requires sch 80 PVC, or can I use sch 40? I'd prefer to use LBs and I've never seen them for EMT.
Check out my on-going Project Thread!
Current Project: Whole House Data Wiring
Back Burner: Drywall Patching
Planning: Kitchen Reno
Thadius856 is offline   Reply With Quote
Old 08-11-2012, 11:38 AM   #17
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Its usually not legal, but so overlooked in most states, not sure if by choice, lack of code knowledge, or just a 'thats the way we do it' mentality....
The other issue is you cant run NM outdoors in a conduit....
Old 08-11-2012, 11:53 AM   #18
Thadius856's Avatar
Rewards Points: 504
:o
Remind me to never post a picture of my main panel.
I've got AC wiring (NM) in one 3/4 flex tubing, one 14-2 NM in 3/4 flex, my dryer line and a 12-2 in a 1-1/4 EMT... none of the inspectors caught any of it wen I bought the place.
Old 08-11-2012, 12:26 PM   #19
E2 Electrician
:o
Like a said, its done all the time... doesn't make it any more right, but ignored none the less. It's a west cost thing, on the east cost you mostly find panels in the basement, at least up north...
Old 08-11-2012, 12:38 PM   #20
Thadius856's Avatar
Rewards Points: 504
No freezing (here), no ice dams, no basements, water heater straps... Finding plenty of differences.
Old 08-12-2012, 07:20 AM   #21
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Finally got back to this one...
Our state had amended this code rule. That it why it wasn't making sense. It eliminates 312.5 (b) which is probably why it is so difficult to meet all those exceptions.
The Following User Says Thank You to k_buz For This Useful Post:
stickboy1375 (08-12-2012)
Old 08-12-2012, 07:49 AM   #22
Licensed electrician
Rewards Points: 1,872
One problem with runnings the MWBC's is going to be how to AFCI protect the circuits.
Old 08-12-2012, 07:52 AM   #23
Rewards Points: 1,192
And I don't use 3 wire circuits. One code cycle it's approved,then they get into afci's and you are stuck when home owners want them put in later.
bobelectric is offline   Reply With Quote
Old 08-12-2012, 07:58 AM   #24
k_buz's Avatar
There is going to be a change here soon that anytime you replace a receptacle, you will need to have it on an AFCI. Well, what if that recept is part of a MWBC? Being that they do not make an approved AFCI device (receptacle) yet and even if they did, in order to use it, you have to meet certain criteria. I know is some parts of the country they make you install them when upgrading a panel. What do those guys do when there are MWBCs existing?
Old 08-12-2012, 08:07 AM   #25
E2 Electrician
They sell two pole afci's... Not a big deal.
Insulate Attic, solar screens, attic fan- biggest bang for buck? heidabear Insulation 6 08-03-2012 11:25 PM
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 03:07 PM
Attic venting questions lemmy Roofing/Siding 36 05-28-2011 08:14 PM
Ventilating attic with two roofs senorbungle Building & Construction 2 01-09-2011 04:17 PM
Attic fan options P550 Roofing/Siding 1 08-22-2010 12:47 PM
