-   -   Getting Into Exterior Walls (http://www.diychatroom.com/f18/getting-into-exterior-walls-165719/)
sirsparksalot 12-06-2012 03:16 AM
Do we always need to cut out an access hole in the drywall to get through to the attic?
I'm trying to drill down from the attic with a flexible bit (18"). I'm installing receptacles on outside walls, and encountering the small space in the attic where the roof slopes; there's only about 1" of space between where I need to drill and the rafters above, and I can't get a drill in there to drill down.
I'm wondering, though, if I could go at an angle (from below) toward the header with a 7/8" x 1' or so bit and get into the header. This would make only a 7/8" hole that could spackle, rather than a doing a larger hole that would require more work.
What's the best way to get into the top plates when confronted with such an attic space?
rjniles 12-06-2012 04:52 AM
You could probably get the wire up thru the top plate into the attic with you ides but how would you get the wire down to the box?
I usually cut a neat 4" square hole about an inch below the ceiling.
joecaption 12-06-2012 10:29 AM
If the outlets going outside why are you not jumping off an outlet from within the room instead of coming from the attic?
Is there a crawl space or basement?
AllanJ 12-06-2012 12:09 PM
An experienced person examines each individual case (individual situation ) and makes an educated guess as to the best way.
Sometimes he drills two holes, one angling up from the inside wall near the ceiling below and another angling down from above, and they meet in the middle with just one hole going all the way through to the outside where the receptacle will be installed.
sirsparksalot 12-06-2012 01:33 PM
No crawlspace or basement, unfortunately.
I'm not installing a receptacle outside; all are inside, but on an exterior wall. How would you suggest I get into, say 2 wall studs, and around the corner to the new receptacle?
jbfan 12-06-2012 01:49 PM
A right angle attachment and stubby spade bits.
Milwaukee makes a bit that is supposed to start at any angle then allow you to straighten it up after you are in the wood.
sirsparksalot 12-08-2012 01:53 AM
The ceilings are only 8', so it should be easy enough with a fish tape, or glow rod.
I'm just wondering if I could drill up at an angle without making the normal 4"-6" cutout in the drywall.
OK, so I got this idea from this video, and I'm wondering just what the hell he's going to do with the top end of the cable>
http://www.youtube.com/watch?v=5o7l1_pRFkU
