GE's "double Pole" AFCI - Electrical - DIY Chatroom Home Improvement Forum
Old 01-23-2012, 07:35 PM   #1
Rewards Points: 33
GE's "double pole" AFCI
I want to use AFCI for the living room, but it's on a shared neutral with the sump pump. My box is an old GE panel from 1969. Running a separate neutral would be impossible without a lot of effort & $$$. Siemens is the only company I know that makes a 2P AFCI, but can't approve it being used in other brand panels. (even though it'll fit)
GE does have a method to wire two single pole breakers to form a double pole.
http://img198.imageshack.us/img198/2949/28187417.jpg
But how does even this work? Is the second breaker even doing anything? What's to stop me from just using a normal breaker for the pump (red wire) and just take the neutral and put it on the afc? I know GFCI can't work that way, but this seems weird.
Sliding Man is offline   Reply With Quote
Old 01-23-2012, 07:57 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 144
I'm not sure of the diagram either.
You can put a small siemens subpanel in and install the 2 pole afci that way.
Old 01-23-2012, 09:46 PM   #3
Rewards Points: 3,256
I see what they are doing and it will work. Very ingenious
zappa is offline   Reply With Quote
Old 01-24-2012, 12:50 AM   #4
Semi-Pro Electro-Geek
Rewards Points: 2,860
I don't get it. I would swear that doesn't work. The top AFCI (with the neutral connected) and its load should be fine. But both AFCI's should trip as soon as a 30mA or greater load is applied on the lower circuit (red wire to neutral), since AFCI's sense ground faults at the Class B (GFPE) level. All current that leaves on the red wire returns through the other breaker, creating an imbalance in both breakers. How could this possibly work? Is there another interconnection between the two breakers somehow?
EDIT: OK, so GE's literature says their new AFCI breakers do not use a ground fault CT anymore, and thus a current imbalance does not trip the breaker. I could have sworn the 30mA ground fault trip was part of the UL spec for AFCI, but apparently they are no longer required to do it. So that's how it works. And it ONLY works with this series of breakers.
Murray does make 2-pole AFCI breakers.
mpoulton is offline   Reply With Quote
Old 01-24-2012, 12:58 AM   #5
Sorry for not giving a better explanation. The levers are connected and these breakers have no ground fault sensing.
Old 01-24-2012, 06:02 PM   #6
Rewards Points: 33
In that case it should work with a normal breaker on the pump, right? Because to be honest, I'd rather not put any special type of breaker on the pump.
Old 01-24-2012, 07:06 PM   #7
The living room breaker would trip when the pump started because of the ground fault circuitry. Do you have to use an AFCI for the living room? What is stopping you from using the Siemens.
Old 01-25-2012, 03:54 AM   #8
Rewards Points: 33
I wanted arc fault on the living because there is a lot of outlets covered by furniture and a few extension cords running behind things. Nothing is psychically stopping me from using the Siemens. I just worry about it not being approved for use by the company themselves.
Old 01-25-2012, 12:20 PM   #9
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,286
Re: illustration
What would happen if you took the neutral wire from the top afci breaker and ran it to the neutral input connection of the bottom afci breaker?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
AFCI breaker tripping encounter779 Electrical 8 06-11-2011 05:09 PM
Puzzled with AFCI nuisance trip ravi Electrical 11 06-06-2011 06:27 PM
Need help understanding GFCI & AFCI sheslostcontrol Electrical 14 11-01-2010 12:59 PM
AFCI and 3-wire circuits...ugghh mhops Electrical 11 03-17-2010 12:22 PM
Loose electrical outlets travishume Electrical 30 08-01-2008 08:21 PM
