Originally Posted by joecaption
Sounds like your talking about a simple black light.
I guess you could say it is a blacklight due to the fact that its running uv lighting. But black lights are uv-a(longwave) rather than uv-c(shortwave). The uv-c is harmful to bacteria(and us) and is known to cause cancerous cells to form and grow. The reason being is that it effects the dna structure of such biological things.
I plan on building a circulating structure that will house the light fixture and also the "containment cell". The containment cell will connect to the fishtank and the fishpump. The pump will draw water into the containment cell which will be split into two sections(both being lit by the UV light). The water will flow into the top of the first section then flow through the bottom into the second section with will house a simple "sponge" that will collect the fine particals. From the second section the water will flow from the top through the pump and into another filter which will house another "sponge", charcoal, and my biofilters.
The reason for this addition to my tank is because i have always had a bad problem with brown algae and i think this will be the best/least harmful to my tank.
A simple blacklight will not do the trick at killing bacteria. If it does i will be VERY impressed and concerned for the public.
Anyways what im thinking of getting the G23 light and fixture.
Here is the socket that im looking at:
G23 Socket.
And the
G23 Bulb
Will this socket be able to directly wire into a powercord that can be plugged into a normal outlet?
