Genset Engineering Calc - Mobile IPhone/iPad Application - Electrical - DIY Chatroom Home Improvement Forum
Old 08-22-2012, 11:45 AM   #1
Hi,
Please advices us how you find this app useful to genset(generator) industry people. Your kudos and comments are welcomed ...
Download link - Genset Engineering Calc @ Apple Appstore
"Genset Engineering Calc" is a handy iPhone App, packed with Electrical & Engine calculators related to generator industry. The App is best suited for Genset professionals and students.
No need of internet connections to calculate, save & load calculations. So very convenient tool to use in engine rooms.
Other additional features -
# The formulas and related info is bundled with each Calculator
# Save calculations for future reference
# Load previously saved calculations
# Share the calculations via Email or SMS
Engine Calculators
I. Power Calc - Can be used for phases 1,2 & 3. Find
+ Power in kVA or kW or hp
+ Current(A)
+ Voltage(V)
II. kVA ↔ kW ↔ hp Converter. Convert ...
+ kVA ↔ kW
+ kW ↔ hp
+ kVA ↔ hp
III. Reactive Power Calc - Can be used for phases 1,2 & 3. Find
+ Reactive power(kW)
+ Current(A)
+ Voltage(V)
IV. Voltage Calc. Find
+ Voltage(V)
+ Current(A)
+ Resistance(Ω)
V. Gen Electrical Power Calc. Find ...
+ Electrical power(kW)
+ Expected Mechanical power(kW)
VI. Voltage Regulation Calc. Find
+ Voltage regulation(%)
+ Voltage @ no load(V)
+ Voltage @ full load(V)
VII. Resistance ↔ Color Code
+ Find resistance from a color band
+ Color bands for a resistance
VIII. Cable Areas ↔ Current Standard - Current Ratings for cables
Engine & Motor Calculators
I. Engine Power Calc. Find ...
+ Power(kW)
+ Engine speed(RPM)
+ Torque(Nm)
II. Mean Effective Pressure (PME) Calc. Find ...
+ Mean Effective Pressure(MPa)
+ Displacement(l)
+ Engine Speed(RPM)
+ Engine Power(kW)
III. Engine Torque Rise Calc. Find
+ Torque rise(%)
+ Peak torque(Nm)
+ Torque @ rated speed(Nm)
IV. Engine Speed Droop Calc. Find
+ Speed droop(%)
+ Full load rated speed
+ No load high idle speed
V. Fuel Consumption Rate Calc. Find
+ Fuel Consumption Rate(l/h or m/h) - from Specific Fuel Consumption(kg/kWh), Power(kW) & Fuel density(kg/m)
+ Specific Fuel Consumption(kg/kWh) - from Fuel Consumption Rate(l/h or m/h), Power(kW) & Fuel density(kg/m)
+ Power(kW) - from Fuel Consumption Rate(l/h or m/h), Specific Fuel Consumption(kg/kWh) & Fuel density(kg/m)
VI. Engine Frequency Calc.Find
+ Engine frequency
+ Engine speed(RPM)
+ Pulses/Rev.
VII. kVA ↔ kW ↔ hp Converter. Convert ...
+ kVA ↔ kW
+ kW ↔ hp
+ kVA ↔ hp
VIII. Motor Frequency Calc. Find
+ Motor Frequency - from Motor Speed(RPM) & No. Poles
+ Motor Speed(RPM) - from Motor Frequency & No. Poles
OntriyumSoft is offline   Reply With Quote
Power loss carlko Electrical 55 03-12-2011 05:26 PM
mobile home service to bond or not to bond rikmac Electrical 35 03-17-2010 03:47 PM
