Old 05-17-2012, 06:13 AM   #1
Generators
It seems to be very popular for people to be installing gennys,
What do you think, is the main reason, that it is so popular now ?
Are people concerned about reliability of supply?
Are black outs becoming more common ?
Whats the reason ?
dmxtothemax is offline   Reply With Quote
Old 05-17-2012, 07:29 AM   #2
Generators
When power is knocked out by storms, it is often out for days or even weeks. You can lose all your food in freezers/refrig. not to mention just existing without power. We still have to eat/cook, most of us need to go to work, etc. Candle power may have worked for Abe, but not now.
Old 05-17-2012, 07:53 AM   #3
biggles's Avatar
Generators
the trick is to install them when you don't need it.set it up,test run it (no load) ever weekend for 20 minutes(keeping gas oil fresh).food and heating is the biggest reason along with 115V for the FIOS stuff and their signal module.you would be surprise how little WATTS a home uses during a normal night at home....2000W tied into your main panel and be somewhat conservative and the neighbors will be knocking on your door with extension cords
Old 05-17-2012, 08:27 AM   #4
Missouri Bound's Avatar
Generators
Whats the reason ?
I"m not sure what everyone else is thinking, but I did my install because of power outages due to ice storms in this part of the country. It isn't uncommon to have a few days outage here once or twice a year. The cold, the dark, the quiet and throwing out $250 worth of food (minus what we could stuff ourselves with in 4 days) was my decision maker.
Do you want it your way or the right way?
Old 05-17-2012, 09:21 AM   #5
Super Moderator
Generators
No working sump pumps is one good reason---
Missouri Bound (05-17-2012)
Old 05-17-2012, 02:35 PM   #6
Generators
1) Manufactures are making it easy for general households by providing turnkey equipment and accessories.
2) It's fun to gloat while your neighbors are in the dark.
3) Life revolves around electricity more than ever.
zappa is offline   Reply With Quote
Old 05-17-2012, 04:25 PM   #7
Generators
Typical Freezer, but also well pump. No power no water
Techy is offline   Reply With Quote
Old 05-17-2012, 06:23 PM   #8
It was a dark and stormy
Yoyizit's Avatar
Generators
How much per year for an insurance policy against these losses?
An idling vehicle can probably put out way enough kW to run a generator but how to do the power take off and how to maintain 60 Hz?
Old 05-17-2012, 06:34 PM   #9
Master Electrician
Generators
I've done quite a few generator side jobs. I grew up out in the country and power outages are far more common there, sometimes up to three days at a time. Most of them all have generators already in and around the 5000w range. Running extension cords in through the door in the middle of winter is a pain. In more rural areas the most common reasons are to power the blower fan in the wood furnaces( you can't keep a fire in an airtight furnace with no blower, the fire box will crack) to keep the water lines from freezing and to run the well pump so there's water, albeit cold water. I generally set them up with a genny panel with a dual interlock to make it idiot proof. Weather proof 30A twistlock receptacle outside and a 30A twistlock cord to run from the genny to the house. Once i did the first one and word got around on what it would cost to still have lights, t.v, microwave, HEAT, and water, and some other general use things my phone starting ringing like crazy . As others have already stated the food loss alone can pay for it in a couple years worth of outages and if a pipe bursts well it's well worth it for most to have the piece of mind.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 05-17-2012, 07:24 PM   #10
Semi-Pro Electro-Geek
Generators
I've wanted a good solution for this to power tools from my truck. It's harder than it should be. There are no good or reasonably priced under-hood generators available. High power inverters are affordable nowadays, but getting the 12V power to run them is a problem. A typical alternator maxes out at about 150A (1800W), and that's at high engine RPM. At idle they won't do more than a few hundred watts. Huge alternators are available (300A or so), but they don't fit many vehicles without modifications and they are very expensive and questionably reliable. And they still only produce 3-4kW max. So while you can get a 5000W inverter for a few hundred bucks, it will kill your battery in minutes even with the engine running unless you do a whole bunch of expensive custom work to add multiple high-output alternators to your vehicle.
mpoulton is offline   Reply With Quote
Old 05-17-2012, 08:23 PM   #11
Generators
I had to get real creative to keep all the fish alive during the big mid-west outage years back.
forresth is offline   Reply With Quote
Old 05-18-2012, 12:08 AM   #12
Wire Chewer
Red Squirrel's Avatar
Generators
I'd say the prime reasons are:
- Fridge/freezer
- Heat
- Sump pumps if house is below sewer/storm drain grade and can't drain by gravity
Extra bonus is the convenience, can still use the microwave and other electric cooking appliances.
In my case I'll add servers to the list. While they do not host anything that crucial, having a 24/7 machine get turned off can sometimes be problematic if you still rely on it a lot. Older disks that have been spinning non stop for years may fail to start again when turned off and let cool down. The chances are good it will be ok, but if you can prevent it in first place even better.
I've been brainstorming a UPS solution for a while and finally found a good product (Tripp Lite inverter-charger) and that is basically my "generator". It's basically the same idea as a UPS except you can hook it up to larger/more batteries. I got 2 12v deep cycle marine batteries that I'll be hooking up to it. Will run my stuff for about 5-6 hours according to my calculations. Debating on adding two more batteries so I can get 10+ hours out of it. The outages here usually don't last more than an hour or so. The longest we had was the great blackout and it was maybe 12 hours at most. I'd still like to look at a generator at some point though.
Old 05-18-2012, 12:09 AM   #13
" Euro " electrician
frenchelectrican's Avatar
Generators
Yoyizit.,
One of my truck I have a PTO ( power take off ) that hook up to the generator unit which it is a 10 KW unit and ran with the maunal throttle contol on diesel engine ( this have mechial pump system so I can able set it pretty tight on speed control )
But on second truck I have simauir but the diesel engine is electronic controlled so I modifed the cruise control for manual throttle useage but that one have 12 KW triphase in there.
But the key issue is you have know how much fuel you have in your tank and with the diesel at PTO mode it will burn about 1.15 to 1.75 gallon fuel per hour so you will have to figure out what is your running time on your fuel tank size. ( my thumb of rules ., Jamais let it go below 1/4 tank level at all )
Merci,
Marc
Old 05-18-2012, 12:38 AM   #14
Generators
Originally Posted by frenchelectrican View Post
Yoyizit.,
Man, you've got some bada$$ gear. Well done.
The Following User Says Thank You to mpoulton For This Useful Post:
frenchelectrican (05-19-2012)
Old 05-18-2012, 06:19 PM   #15
Generators
So the main reason would seem to be frequent loss of power ?
Maybe it is different here in Australia ?
Maybe two / three blackouts a year,
usually short, less then 2 hours.
Major blackouts are not common !
Perhaps one every 2 to 3 years,
where power could be off for several days.
And even then, they seem to get it restored
even if only partiually quite quickely !
But most of our water supplies are gravity fed
from storage tanks in evevated areas,
so even with out power,
gravity will supply most pf the supply.
usually 2 to 3 days supply with out power.
And sewerage stations all have back up gennys.
You guys seem more de centralised then us here in Australia ?
Perhaps that is the main difference ?
should I buy these generac generators for 100. each? vintagecarlover Electrical 7 05-03-2012 10:36 AM
Generac Generators sbkim Electrical 5 05-02-2012 06:23 PM
Why can't some generators run appliances that use an induction motor? Deck Electrical 10 11-07-2011 03:51 PM
Standby Generators JKE General Discussion 5 06-15-2009 12:09 PM
Important about Generators Mike772 Electrical 8 04-29-2006 05:50 PM
