Generator Transfer Switch For Meter/Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 02-21-2012, 12:25 AM   #1
Generator Transfer Switch for Meter/Panel
Hey everyone!
I have a Cutler Hammer Meter/Panel Outdoor combo that feeds my interior panel with 200 AMP service.
As you can see, it has the main breaker, and then two breakers in use, one for a GFCI outlet directly below the panel, and another for the RainBird Irrigation Controller, also right next to the panel.
All the other breakers are inside the garage in a subpanel.
While we have yet to loose power for greater than 45 minutes in the history of the town, I am looking to be prepared with at least a generator inlet should the need arise.
I would like to either use an interlock kit, or a large manual transfer switch to connect the generator to the home.
Cutler Hammer makes an interlock kit, however I am having difficulty in finding the correct one for my panel. Here is the label on the inside of the outdoor meter/panel.
Any thoughts/help would be appreciated.
Thanks!
-Eric
EOppegaard is offline   Reply With Quote
Old 02-21-2012, 11:27 AM   #2
Rewards Points: 160
www.interlockkit.com
Old 02-21-2012, 01:55 PM   #3
Thanks JV for the link.
I have already checked out interlockkit.com, as well a generlink, reliance, and others.
While they do list solutions for a Meter/Main combination, they do not list a specific solution for my CMB series panel.
Cutler Hammer also has a listing for interlock kits, however once again not for my CMB series panel.
Still would welcome any advice/thoughts.
Old 02-21-2012, 02:03 PM   #4
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Does your panel inside have a main?
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-21-2012, 02:07 PM   #5
No it does not. As it was described to me, the main breaker (Service Disconnect) on the outside panel feeds the subpanel inside the garage.
Old 02-21-2012, 02:14 PM   #6
rrolleston's Avatar
Maybe a manual transfer switch between the main panel and the sub panel.
Old 02-21-2012, 02:27 PM   #7
I assume you are referencing a 3 way switch, similar to this:
The highest commonly available transfer switch I can find is 125A.
http://www.electricgeneratorsdirect....5DR/p1125.html
As I have a 200a service, I assume I also need a 200a rated transfer switch.
Old 02-21-2012, 02:36 PM   #8
rrolleston's Avatar
Local electric supply should have one probably looking at about $500 for the switch though.
Old 02-21-2012, 02:38 PM   #9
rrolleston's Avatar
The one in your link looks like a solution.
Old 02-21-2012, 02:42 PM   #10
Yeah I was afraid of that. I had looked at a few of those and $500 would be on the less expensive side for many of them.
Interlockkit.com believes their K-6010 kit would work for the exterior panel, however I am not a big fan of "believes"
Old 02-21-2012, 02:50 PM   #11
rrolleston's Avatar
Here is something to look at too.
http://www.ebay.com/itm/Square-D-H32...item2eb2fe11fc
Old 02-21-2012, 02:58 PM   #12
That is just a 3 way switch with no air gap, so technically it is not a transfer switch. From what I understand that does not meet code.
I also had seen this, and figured while "automatic" I could use it with a portable genset inlet, it just switches itself.
http://www.ebay.com/itm/Generac-RTS-...#ht_500wt_1204
Old 02-21-2012, 03:03 PM   #13
rrolleston's Avatar
Ops my bad price was too good to be a transfer switch anyways
That is a very nice transfer switch.
I would try the interlock kit they think will work. Could always send it back.
Tags
florida , generator , generator interlock , transfer switch
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 07:25 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
1 pole + 3 way switch momof2labs Electrical 1 05-22-2010 10:37 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
