Generator Transfer Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 02-20-2011, 11:37 PM   #1
I installed a 30 amp Gen Tran Switch on a Square D Homeline panel. I read somewhere that I would not be able to turn on the arc fault circuits. Wondering why this is or if it is true. Thanks.
fullnelson is offline   Reply With Quote
Old 02-21-2011, 12:33 AM   #2
Scared Electrician
Saturday Cowboy's Avatar
I have never heard this and have no logical reason to believe it to be so. Not saying it ain't true but you would have to have some irrefutable evidence in hand before I believe it. Breakers are not picky as to where the juice comes from just that it does not arc down stream of them.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 02-21-2011, 12:54 AM   #3
" Euro " electrician
frenchelectrican's Avatar
I have not heard that as well but really basically if you have proper voltage range and HZ { this is kinda critical for some items to function properly } and it should have no issue running on generator mode.
So if you run the generator run thru the convental breaker first to make sure you have proper voltage and HZ then kick on the AFCI breakers I am pretty sure it should not have a major issue with supply side however some generators can produce dirty electrical source it may kick out the AFCI or GFCI so check it out before you have actual power failure and find out in hard way so do it asap.
Merci.
Marc
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
1 pole + 3 way switch momof2labs Electrical 1 05-22-2010 10:37 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
