Old 08-26-2012, 08:03 AM   #1
jf9770's Avatar
Generator Transfer Switch
I am planing on installing a wall mounted transfer switch to my electric
service panel in my garage however the instructions show the conduit
from the switch going into a knock out hole in the bottom of a wall mounted service panel box. My service panel is built in to the wall. how do I access the panel with the conduit from the transfer switch and make it look neat?
What do the electricians use to make it look neat in the wall. Is their a knock out in the bottom of the panel inside the wall?
jf9770 is offline   Reply With Quote
Old 08-26-2012, 08:32 AM   #2
Licensed Electrician
k_buz's Avatar
There really isn't much of a choice. You are going to have to open the drywall. The next problem you are going to encounter is the studs covering up the side KO's.
Location...Location...Location
Old 08-26-2012, 11:16 AM   #3
Jack of all Trades
lifestooshort81's Avatar
I'm not an electrician but have worked for plenty and have common sense.
My suggestion would be to use either EMT or plastic conduit. Ok now for the caveat...depending on your local code. If this is for yourself then code, schmode! Do it do it's safe. If its for a customer well, use your best judgement.
Anyway, there are knockouts in the electrical panel. Usually on the top bottom and sides. You may have to remove a section of the wall to access it but it's there. If not you can buy a greenlea punch. They're pricey but harbor freight has them too at beyond half price. Sometime they're colloquially called a "slug buster".
Hope this helps!
lifestooshort81 is offline   Reply With Quote
Old 08-26-2012, 11:21 AM   #4
k_buz's Avatar
Seriously?
Old 08-26-2012, 11:47 AM   #5
Master Electrician
Hope this helps!
Great idea......until he goes to sell the house and the home inspectors start flagging things. More and more people are starting to get wise to this sort of thing with the huge amount of shows on t.v with people getting screwed buying houses not up to standards.
Not to mention if its in the code its there for safety reasons.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
1 pole + 3 way switch momof2labs Electrical 1 05-22-2010 11:37 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 08:11 AM
