Generator To Transfe Switch Wire Gauge - Electrical - DIY Chatroom Home Improvement Forum
Old 07-18-2012, 06:26 AM   #1
Generator to transfe switch wire gauge
So I'm runnin the wire from my out side hook up to the transfer switch. This is a 5500 watt 30 amp generator. The wire is going to be 25 feet long. What gauge do I need. I've seen some tables where it looks like I need 4 gauge but others say I need 10. Which is right? Or are both wrong?
Kirk5291 is offline   Reply With Quote
Old 07-18-2012, 07:02 AM   #2
Rewards Points: 1,502
You can use #10 gauge provided there is a 30 amp breaker permanently in the line, for example a small panel before the outdoor hookup (inlet; male receptacle).
You may choose to use heavier wire and matching hookup (#8 for 40 amps, or whatever) to plan for the future in case you decide to get a larger generator.
AllanJ is online now   Reply With Quote
Old 07-18-2012, 07:13 AM   #3
Master Electrician
10 is all you need but if you ever plan on maybe going bigger you may want to run 6's. That next twistlock size up is 50a for a genny.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 07-18-2012, 11:31 AM   #4
Thanks .. Guess I'll run 6 just cause I want to only do this once
Tags
gauge transfer switch
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 07:07 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
Wire Multiple Lights controlled by 4-way Switch? mfleming Electrical 17 11-20-2008 08:46 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
