Generator Sub Panel Is This Wiring Correct? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-25-2013, 04:19 PM   #1
Generator Sub Panel is this wiring correct?
Hey All...
I got around today to hooking up the wiring for my GenTran transfer switch.
I only hooked up one circuit, and took some pictures to see if I was on the right track.
Let me know how it looks.
One thing I had a question with... Why on the main panel are the grounds and neutrals on the same bars?
Thanks, this site has been A++ so far!
Generator Sub Panel is this wiring correct?-photo-4-.jpg   Generator Sub Panel is this wiring correct?-photo-3-.jpg   Generator Sub Panel is this wiring correct?-photo-2-.jpg   Generator Sub Panel is this wiring correct?-photo-1-.jpg   Generator Sub Panel is this wiring correct?-photo.jpg
Durkis007 is offline   Reply With Quote
Old 01-25-2013, 04:57 PM   #2
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Trying to figure out what is going on here. Does this feed back into your main panel or are you feeding the transfer switch with the main panel and moving the circuits to the gen tran panel?
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 01-25-2013, 05:06 PM   #3
Sorry.. Should have been a bit clearer with my description.
The GenTran transfer switch is on the right in the photo, and the main panel is on the left. There is no extra sub panel. Just the main and transfer switch.
Hope that helps
Here is a link for the gentran 300660 install manual...
http://www.gen-tran.com/assets/pdfs/50050I.pdf
Old 01-25-2013, 05:13 PM   #4
The wiring that I added..
1)Blue wire from the CB on the switch to the black lead in the main panel.
2)Green wire, from the ground bar on the switch to the ground / neutral bar on the main panel.
3)White wire from the neutral bar on the switch to the ground neutral on the main panel.
4)Two Black hot wires from the 60amp breaker in the main to the 60amp breaker on the switch.
Old 01-25-2013, 05:49 PM   #5
Lic Elect/Inspector/CPO
From the pictures it looks good.
NJMarine is offline   Reply With Quote
Old 01-25-2013, 06:03 PM   #6
rrolleston's Avatar
Is that green bonding screw screwed into the transfer panel?
Old 01-25-2013, 07:03 PM   #7
Missouri Bound's Avatar
The are on the same buss in the main, but seperated in sub-panels. And they aren't an issue with your transfer panel.
Do you want it your way or the right way?
Old 01-25-2013, 09:48 PM   #8
Rolleston, yes the green bonding screw is in on the transfer panel. Is that a problem?
I do remember reading a post on here a bit ago, since I have the metal conduit between the two panels, if that would be a problem or not ?
Old 01-26-2013, 02:14 AM   #9
rrolleston's Avatar
No problem it's needed to bond the ground to the panel.
Sent from my iPhone using DIY Forum
Is it normal to have the furnace control panel wiring, not match the wiring diagram cjbeck71081 HVAC 6 07-18-2012 11:19 AM
new sub panel BlueBSH Electrical 11 01-22-2012 08:28 AM
Wiring a sub panel ZBat910 Electrical 6 01-08-2012 02:00 PM
Sub panel wiring and voltage drop questions CPF Electrical 6 11-30-2011 07:52 AM
wiring an electric sub panel located 130 ft from main panel jaramillo Electrical 4 06-04-2011 07:46 PM
