#1 |
Generator sizing to match existing Panel
I moved into a new house in June that already had a a "make and break" breaker for a generator (70 amp breaker) and 30 amp 4 pole plug on the outside of the house
My question is what size of generator output is needed to feed this. Minimum load I have from what feed from the generator panel is water pump, fridge, freezer, a pellet store (just normal plug in to auger and fan) and a few lights. I understand most electrical theory when explained but do not have the experience with electrical to figure out on my own! |
#2 | |
It was a dark and stormy
Generator sizing to match existing PanelQuote:
peak load of things with motors can be 5x to 10x higher than steady state load, for a second or so. |
#3 |
You will need some help from our European expert "Frenchelectrician" on the requirements in Canada.
I can tell you that the 70 amp breaker and a 30 amp receptacle do not jive. Keep checking back. |
#4 | |||
" Euro " electrician
However you may want to look at the surge wattage rating as well beside of running watts the surge will able help momteray get the motor load start up. Quote:
Do you have subpanel for generator use or have both main breaker and generator breaker inside the breaker box ? let us know we will go from there. Merci,Marc |
#5 |
TDN - The breaker for the circuits that can be feed from the generator is a 70 amp breaker, and the plug outside is 30 amp I thought that it was "different" therefore holding off buy a generator till I understand it. The panel was replaced not that long ago and was done by electrican (not a DIY).
Not sure if this helps? I am not at my house right now to try to verify the conductor size |
| Display Modes | |
| 100 amp sub panel | Donald A | Electrical | 9 | 03-25-2009 01:29 AM |
| GFCI feeing subpanel question | scott2332 | Electrical | 45 | 02-28-2009 04:15 PM |
| Melted Service Entrance Wire in Panel | theatretch85 | Electrical | 13 | 08-22-2008 11:37 AM |
| breaker panel question | chadvavra | Electrical | 11 | 08-10-2007 10:20 AM |
| Outdoor breaker panel questions | lhoney2 | Electrical | 12 | 07-19-2007 06:44 PM |
