Generator Safety Switch Help - Breaker Size? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-07-2008, 06:29 PM   #1
What a great site, and want to thank everyone in advance for taking time to answer my question (s). I'm sure not a professional, as you will see in my question (s). Years ago, I built a home for myself, and now building one for my mother, who due to her health needs to be on a one floor plan. For the most part I've done all the work myself, by researching the net or reading books, I just can't find an answer to this question.
Installing a generator transfer switch, tied into a Square D QO box. I've used 12 gauge wire and 20 amp breakers to wire the whole house. The transfer switch reset buttons, singles show 15 amp on them, and the double show 20 amp. Would this require 15 amp and 20 amp breakers respectively to match the resets?
And if you don't mind one other quick question? Installing AC smoke/carbon monoxide alarms with battery backup, to be interconected. I know you CAN use 14-3, but can I use 12/3, seeing I already have some left over?
Again thanks in advance for any advice given. Regards.....Limey
limey_swindon is offline   Reply With Quote
Old 01-07-2008, 07:25 PM   #2
Union Electrician
goose134's Avatar
Need more info for the generator question. Maybe a link to manufacturer or a schematic? The smoke/CO interface may be wired with 12/3 or 14/3.
goose134 is offline   Reply With Quote
Old 01-07-2008, 07:41 PM   #3
Hi, it's a generac, gasoline, 7500 watt generator. The 4 prong extention cord will come off the generator and plug into the outlet box located on the outside of the house (pb30), which in turn will plug into the front of the generac 10 circuit safety switch, which in turn wires into the appropriate circuits in the main breaker box. the switch itself had 6, 15 amp circuits and 2, 20 amp double circuits (which can be seperated to make into 4 individual circuits). my question is, do the 15 amp circuits in the safety switch have to match up with 15 amp circuits in the main breaker box? all the wiring going into the main breaker box is 12 gauge or heavier. hope this helps you answer my question. regards...limey
Old 01-09-2008, 11:40 AM   #4
Rewards Points: 126
No, they don't have to match up. You will just have 15 amp protection on a 20 amp circuit. The wire can be larger than needed, but not smaller. How are the connections made in the main panel? Where the transfer switch wires connect to the building wires?
If it worked before you worked on it. You did something wrong.
Wiring a compressor scrapin Electrical 25 03-18-2012 11:35 PM
Wire size and Breaker size for remodel ?? Skydmark1 Electrical 12 12-15-2007 05:00 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
Light Switch Keeps Tripping Breaker jackiesmom Electrical 23 05-24-2007 02:27 PM
neew light switch... on is ok(ish), off flips breaker Nat0570 Electrical 10 05-05-2007 05:02 AM
