Generator Power Transfer Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 06-25-2012, 07:49 PM   #1
jburd964's Avatar
Rewards Points: 166
Generator power transfer switch
I'm wanting to run a supply line from my 15kw generator to supply my home in a emergency. Would a double throw transfer switch be what I need to isolate my power from the grid?
I'm not a professional., But I did stay at Holiday Inn Express last night.
Gun control isn't about guns, IT'S ABOUT CONTROL.
jburd964 is offline   Reply With Quote
Old 06-25-2012, 07:52 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
For something that size, I would look for a breaker interlock. Unless you want something that changes over automatically.
Old 06-25-2012, 07:58 PM   #3
jburd964's Avatar
Rewards Points: 166
Would you explain the difference in the two?
Old 06-25-2012, 08:17 PM   #4
Missouri Bound's Avatar
A breaker interlock switch is a simple installation, requires only wiring the generator to a back feed breaker. A transfer switch will require quite a bit more wiring to affect the same result. Either way, a 15kw generator will pretty much allow you to use most of your circuits, with only a few exceptions. This is a portable generator, I assume?
Do you want it your way or the right way?
Old 06-25-2012, 08:50 PM   #5
jburd964's Avatar
Rewards Points: 166
It's a PTO driven generator. I'm going to do some research on the interlock. What im calling a double throw breaker, does in one action/throw removes your feed from grid an places you onto your standby power source eliminating potential of someone being electrocuted or generator from being fired form back feed.
Old 06-25-2012, 08:59 PM   #6
k_buz's Avatar
That is a nice set-up, but can be quite pricey. A breaker interlock is cheap...if you have a "standard" panel you can get one for less than 50 bucks.
The interlock is the metal lever installed on the breakers. It won't allow POCO power and emergency power to be on at the same time.
Old 06-25-2012, 09:04 PM   #7
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
http://www.interlockkit.com/
Old 06-25-2012, 09:18 PM   #8
jburd964's Avatar
Rewards Points: 166
It may be helpful to state that my main feed comes from under ground to the outside wall of home. My house has spray foam insulation and my main breaker panel is inside on a wall away form external main.
I looked at the interlock system and that would be a lot cheaper than the double throw setup but I think I'll have to go that rout seeing as I can't pull new wires to feed inside breaker panel. Any other suggestion would be appreciated.
Old 06-26-2012, 09:42 PM   #9
Master Electrician
depending what you want to do with your generator you can pick up a generator panel from a big box store for around $160, it has the interlock built in. You basically feed one side of the main from a 30A breaker and the other side of the main from the generator. what i generally do is install a weather proof 30A twistlock plug on the outside of a house and run it to the genny panel. build them an extension cord with two male ends that plug into the wall and the genny. When the power goes out all they have to do is flip the genny panel breaker plug in the cord and fire up the genny and everything in the genny panel comes back on. It's an idiot proof install.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 06-27-2012, 04:52 AM   #10
dmxtothemax's Avatar
Rewards Points: 5,152
In Australia we dont use metal mechanical type interlocks such as
the one shown in the picture.
Instead we use a DPDT switch.
Probably more reliable in the long run.
And cant be miss used.
Do you use DPDT switchs as transfer switchs ?
Or are they mostely a mechanical interlock type.
dmxtothemax is offline   Reply With Quote
Old 06-27-2012, 09:18 AM   #11
Master Electrician
The issue with the dpdt switch is that the neutral remains connected. In theory the guy trying to fix the power lines could get a whack off your genny if circumstances are right. I'm not sure what the rule is on neutrals in the states or even here in Canada code wise but every genny panel I've ever seen switches the neutrals out as well.
Old 06-27-2012, 09:57 AM   #12
jburd964's Avatar
Rewards Points: 166
These are pictures of my main/meter box.
Generator power transfer switch-image-412589832.jpg   Generator power transfer switch-image-3827745724.jpg   Generator power transfer switch-image-4236881471.jpg   Generator power transfer switch-image-1840010008.jpg
Old 06-27-2012, 09:59 AM   #13
jburd964's Avatar
Rewards Points: 166
Is there a inter lock for such a application? Any suggestions?
Old 06-27-2012, 10:18 AM   #14
This is what you need:
http://www.geindustrial.com/publibra...T-458A|generic
Its 39.97 at HD
http://www.homedepot.com/webapp/wcs/...|e|11593998877
Double check the model of your panel and that kit.
Here is a 50 amp inlet that you can add to the bottom of your meter/main panel, no extra box required:
http://www.homedepot.com/webapp/wcs/...5f%2d202216491
Auger01 is offline   Reply With Quote
The Following User Says Thank You to Auger01 For This Useful Post:
stickboy1375 (06-28-2012)
Old 06-27-2012, 12:23 PM   #15
jburd964's Avatar
Rewards Points: 166
This is great, I was looking to spend $300 on a DPDT switch. Going to get ahold of the permitting office, hopefully this will be good with them and they come up with some crazy crap. Thanks for everyone's input.
Electrical transfer switch dougp23 Electrical 4 11-23-2011 03:22 PM
Portable Generator Transfer Switch Question Dave_T Electrical 1 11-21-2011 05:08 PM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-08-2011 11:00 PM
Meter Socket Manual Gen Transfer Switch Mainebob Electrical 3 05-11-2011 07:31 AM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 02:44 PM
