Old 10-24-2011, 07:15 PM   #1
Generator outlet and propane tank
Have a small 50 gallon propane tank for my gas range.
Ready to hookup my generator wiring. Does anyone know if there are required distances for the outlet the generator will plug into, from the propane tank? It's a portable generator. Called my local building inspector, but he's out this week.
Just curious if anyone has heard what the acceptable distances might be.
dougp23 is offline   Reply With Quote
Old 10-24-2011, 08:44 PM   #2
Semi-Pro Electro-Geek
I doubt there are any rules on this, but if there are, they would not be in the electrical code. The rule would be in the general building code, plumbing code, or fuel gas code.
mpoulton is offline   Reply With Quote
Old 10-24-2011, 09:47 PM   #3
I=E/R
a7ecorsair's Avatar
When the LP line and regulator were set up on my house the heating contractor said the regulator had to be so far from things because the regulator does vent. I don't know what the code is but we put it on the side away from everything.
a7ecorsair is offline   Reply With Quote
Old 10-24-2011, 10:01 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Most bottled gas companies want a minimum of 10' clearance to anything electric or ignition source.
Speedy Petey is online now   Reply With Quote
The Following User Says Thank You to Speedy Petey For This Useful Post:
frenchelectrican (10-25-2011)
Old 10-24-2011, 10:17 PM   #5
liscenced electrician
while i see why you posted it in the electrical forum, somebody that deals with gasses would know more about it
jimmy21 is offline   Reply With Quote
Old 10-24-2011, 11:21 PM   #6
Idiot Emeritus
The electrical code is pretty ambiguous here; the closest thing I could come up with is the propane tank could be considered a bulk storage plant. If so, it would be a class 1 division 2 location.
Table 515.3 basically states that the area more than 10' from any part of the tank (including upward from the top) is not classified.
I believe if you stay more than 10' away from it, you'd be good.
Rob
P.S. If you really want to be confused, just read articles 500 through 516!!
micromind is offline   Reply With Quote
Old 10-25-2011, 02:32 AM   #7
" Euro " electrician
frenchelectrican's Avatar
It will be under Fuel Gaz code and it have to be 10 feet away from the regulatour or tank avce regulatour.
Due the LP gaz is hevier than air so that one reason why they keep that distance.
Merci,
Marc
Propane Mower Conversion homerb Green Home Improvement 18 09-16-2010 01:01 PM
gas (propane) cooktop off a BBQ tank pstock Appliances 0 06-26-2010 10:21 AM
Propane Range hookup to 20lbs tank? PaoloM HVAC 0 06-09-2010 11:47 AM
propane tank switch. waverly guy HVAC 13 09-14-2009 09:25 AM
Propane Tank for BBQ Irregular WayPeter General Discussion 4 03-03-2009 02:28 AM
