Old 10-12-2010, 08:31 PM   #1
Generator Main breaker
I have a B&S 4000 watt pro series generator. The main breaker trips as soon as I start the generator(not under any load at all). I bought and replaced the main breaker with genuine B&S parts. This did not correct the problem. While apart I checked the current and had a steady 240v. Any suggestions on what the problem may be?
Eliwenger is offline   Reply With Quote
Old 10-12-2010, 08:34 PM   #2
joed's Avatar
Wiring short between breaker and outlet plug on generator?
Do not PM with questions that can be asked in a forum. I will not respond.
Old 10-12-2010, 08:35 PM   #3
" Euro " electrician
frenchelectrican's Avatar
If your main breaker on the genrator trip that mean you have wiring issue on the recetpale or a conductor is touching something it should not supposed to.
To check it out make sure your generator is complety off and take the cover off and look at the wiring and see any loose connection that useally the cuprit.
and clean the area out if need to as well.
AND do not touch anything else inside the generator leave them alone.
Merci.
Marc
GFCI Breaker Tripping Spa Light eaposition Electrical 21 09-08-2010 10:57 PM
Breaker box wiring question(s) janralix Electrical 6 08-29-2010 11:13 PM
Breaker Tripping Jeridmar6 Electrical 15 07-10-2010 09:20 PM
20 amp GFCI breaker pops when pool pump is turned on. jagrunner Electrical 11 03-19-2010 05:31 PM
Sq D Trillaint Breaker problem jmreynol Electrical 3 04-28-2009 08:06 PM
