Generator Interlock Kit - Which One? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-12-2013, 07:14 PM   #1
Bought a new house recently and have been going through the panel identifying all the breakers.. making great progress but now I'm on to planning for the generator.
I plan on putting in a basic reliance 30amp inlet box outside to plug the generator in to but I'm having a hard time figuring out what interlock to get.
The panel is an older Square D but it has 200amp 4-pole vertical breaker main with the individual breakers being horizontal. I'm okay with moving breakers around-- have plenty of room. Just looking for the appropriate interlock to protect the 4pole main from the 2pol/30am generator breaker.
Attached are pictures. Any help or suggestions would be greatly appreciated.
https://www.dropbox.com/s/j4b8bf6ajtpc90t/IMAG0014.jpg
https://www.dropbox.com/s/pge19gzvabqzjdf/IMAG0015.jpg
ozzyjunk is offline   Reply With Quote
Old 03-13-2013, 09:08 AM   #2
Electrical Enthusiast
Rewards Points: 504
Welcome,
I don't know if you have looked at interlockkit.com, but you might check there. They have an option of sending in your panel measurements, and they will create a custom kit to match it, if your panel is not listed in one of the brands. I've also read that you can get interlock kits directly from the manufacturer, but I don't know if Square D does this.
Kyle_in_rure is offline   Reply With Quote
Old 03-13-2013, 09:59 AM   #3
Rewards Points: 758
Square D does make interlocks and they usually cost much less than interlockkit.
You need the model numbers of your panel.
AandPDan is offline   Reply With Quote
The Following User Says Thank You to AandPDan For This Useful Post:
NJMarine (03-13-2013)
